I will disclose that I dont use Webodm on windows , but since this has been replied to in 3 days I thought I would chime in on what I do know about Webodm on windows. First it depends on how you installed ODM on your machine. Are you using docker or is it a native install? If docker, there is a settings file for docker you can adjust the resources docker has available (something like wsl 2) . If its a native install it should use all available resources. Anyway hope that someone with more knowledge of webodm on windows can fill you in.
Thanks. I found that WebODM was using all available memory - I just didn’t have enough! To fix that I configured a disk partition I wasn’t using to explicitly provide a 1Tb paging file.
It still doesn’t use much CPU/GPU resources though.
Yes. It is slower because disc is slower than RAM. But it’s cheaper than upgrading my 128Gb of RAM by a factor of 10x!
In the end, I just reduced the quality of my point cloud from ultra to high, whilst keeping the PC count at 10,000,000 and it successfully completed in just under an hour.
