After installing WebODM, it installed Docker, and I got the account set up with that. WebODM throws a Fatal error “Docker is already running”. The WebODM Manager says “Docker is installed but not communicating…” and “Launching Docker…” but after a while if it trying to load, throws another error saying “We had some issues launching Docker. Find the Docker application and start it manually, then restart WebODM Manager.”
I have done that several times with no success. It does the same thing every time. I payed for the installer as well. This is on MacOS Catalina 10.15.16. Any help is much appreciated.
Yes to both. I have restarted the computer, I have tried starting Docker first (and ran code to make sure it works…it does), then ran WebODM. I have uninstalled both programs and tried installing them in reverse order and running them in reverse order as well, and no luck. Same error messages every time.
I am not a coder, so going much further into coding is futile for me Hence…I am here!
And then it gets stuck.
The issue is that I cannot update webodm images, otherwise I can run old containers manually from docker dashboard.
On Windows even after I upgraded Docker to version 2.3.0.5, WebOdm Manager works just fine and does not complain.
Who should be notified about this issue?
Besr regards,
Ok, I updated Docker again, started WebODM and everything ran great until it threw the code 1 error again. That’s after I turned off the thing you said to turn off and restarted the program.
That FIXED IT! Thank you SO much. I was dreading having to spend hundreds of dollars to make a 2D map for my clients. This seems like an awesome solution. The support here is fantastic. Thanks again.
I had the same problem as Shadowpoint and did the docker downgrade from 2.3.0.5 to 2.2.0.3. I then restarted WebODM Manager, which downloaded a whole new WebODM application that installed over top of what I had before. In doing so it appears I lost all of my work/projects from before.
How do I get my projects back?
This is the information from WebODM Manager after I had downgraded and tried to start WebODM…
Docker is installed, but is not communicating…
Launching docker…
Waiting for WebODM to start…
Press Start to launch WebODM
Starting WebODM…
Starting node-odm …
Starting broker …
Starting db …
Starting worker …
Starting webapp …
e[5Ae[2K
Starting node-odm … e[31mfailede[0m
e[5B
e[4Ae[2K
Starting broker … e[32mdonee[0m
e[4Be[3Ae[2K
Starting db … e[32mdonee[0m
e[3Be[2Ae[2K
Starting worker … e[32mdonee[0m
e[2Be[1Ae[2K
Starting webapp … e[31mfailede[0m
e[1B
