Mac Installer
I want to run NodeODM on a M1 so I can do some clustering.
I couldn’t get the manual install to work so I reverted back to my WebODM Mac Installer. It runs fine but all I really wanted to run is nodeODM …so is there a docker-compose.yaml file I can tinker with or is it built in? I also need to change the port that nodeodm is running on …I need something other than 3000 ,again …a docker-compose.yaml would be the fix.
I figured out you have to Docker Desktop and then the git clone … …now to disect webodm.sh to figure out which docker file to change
