Hello.
I am a new user and I’m checking the possibilities of Webodm. After a few sets of data I have questions and problems. I would be grateful for your help.
The project area is relatively difficult - an open-pit mine. There are big differences in hights, high greenery etc. 5 RTK-GCP were used for the project.
- Dense cloud points created by WEbodm has very high noise up to 1 meter.
The same data set processed in Pix4d has a noise of about 0.05m.
Check-points are on the asphalt road. I need high-accurate data for terrain measurements.
Is it possible to use the rerun function using WebODM Lightning? Can the rerun function be used for a completed task?
What options should I use to generate a good point cloud and good orthophotomap?
Using Windows 10, Chrome, manual install of WebODM,
Console output: Data temporarily unavailable on Webodm Ligthning
Processing parameters:
{“uuid”:“8e1dcca4-73a9-4b33-aece-20eb7f8712e6”,“name”:“Poludnie6”,“dateCreated”:1584783506940,“processingTime”:96358439,“status”:{“code”:40},“options”:[{“name”:“pc-classify”,“value”:true},{“name”:“pc-sample”,“value”:0.01},{“name”:“mve-confidence”,“value”:0.8},{“name”:“orthophoto-resolution”,“value”:5},{“name”:“orthophoto-no-tiled”,“value”:true},{“name”:“dem-resolution”,“value”:2},{“name”:“opensfm-depthmap-min-consistent-views”,“value”:4},{“name”:“orthophoto-cutline”,“value”:true},{“name”:“pc-las”,“value”:true},{“name”:“dsm”,“value”:true},{“name”:“depthmap-resolution”,“value”:1000},{“name”:“opensfm-depthmap-method”,“value”:“BRUTE_FORCE”}],“imagesCount”:447,“progress”:100,“output”:[]}
Thanks for the help.
