Login issue
Google Chrome is up to date
Version 86.0.4240.80 (Official Build) (x86_64)
Model Name: MacBook Pro
Model Identifier: MacBookPro11,4
Processor Name: Quad-Core Intel Core i7
Processor Speed: 2.2 GHz
Number of Processors: 1
Total Number of Cores: 4
Software TypeWeb Browser
Hardware TypeComputer
Browser version (full)86.0.4240.80
Operating System version (full)10.15.6
Layout EngineBlink
Configured LanguageEnglish
Device Pixel Ratio2
Browser GMT Offset-04:00
PlatformIntel based Mac
What is the problem?
I was playing around and found the account section then I deleted unknown since the other one showed my name.
I was uploading pictures, I accidentally closed the browser and restarted the system again.
What should be the expected behaviour?
I would have expected to be able to log back into it and complete the project.
Since everything runs till I get told by the system when browser opens that password doesn’t work.
I reset the password on odm manager setting and still no access on http://localhost:8000/login/
I am confused since I use simplified platforms like drone deploy and etc…now this hick up is bothering me since I have paid for it…Should I re-install everything or is there a solution to my problem?
Here is additional information
Waiting for WebODM to start…
WebODM is running. Open your browser to http://localhost:8000
Updating WebODM…
From git://github.com/OpenDroneMap/WebODM
  • branch master -> FETCH_HEAD
    Already up to date.
    Stopping webapp …
    Stopping worker …
    Stopping broker …
    Stopping webodm_node-odm_1 …
    Stopping db …
    �[5A�[2K
    Stopping webapp … �[32mdone�[0m
    �[5B
    �[2A�[2K
    Stopping webodm_node-odm_1 … �[32mdone�[0m
    �[2B
    �[4A�[2K
    Stopping worker … �[32mdone�[0m
    �[4B
    �[1A�[2K
    Stopping db … �[32mdone�[0m
    �[1B
    �[3A�[2K
    Stopping broker … �[32mdone�[0m
    �[3B
    Removing webapp …
    Removing worker …
    Removing broker …
    Removing webodm_node-odm_1 …
    Removing db …
    �[3A�[2K
    Removing broker … �[32mdone�[0m
    �[3B
    �[1A�[2K
    Removing db … �[32mdone�[0m
    �[1B�[2A�[2K
    Removing webodm_node-odm_1 … �[32mdone�[0m
    �[2B
    �[4A�[2K
    Removing worker … �[32mdone�[0m
    �[4B
    �[5A�[2K
    Removing webapp … �[32mdone�[0m
    �[5B
    Pulling node-odm …
    Pulling db …
    Pulling broker …
    Pulling worker …
    Pulling webapp …
    �[5A�[2K
    Pulling node-odm … pulling from opendronemap/nodeodm
    �[5B
    �[5A�[2K
    Pulling node-odm … digest: sha256:4e0db0f0145b3db9c1…
    �[5B�[5A�[2K
    Pulling node-odm … status: image is up to date for o…
    �[5B�[5A�[2K
    Pulling node-odm … �[32mdone�[0m
    �[5B
    �[3A�[2K
    Pulling broker … pulling from library/redis
    �[3B
    �[2A�[2K
    Pulling worker … pulling from opendronemap/webodm_…
    �[2B
    �[2A�[2K
    Pulling worker … digest: sha256:aaeea475b90399d4bd…
    �[2B�[2A�[2K
    Pulling worker … status: image is up to date for o…
    �[2B�[2A�[2K
    Pulling worker … �[32mdone�[0m
    �[2B
    �[4A�[2K
    Pulling db … pulling from opendronemap/webodm_db
    �[4B
    �[4A�[2K
    Pulling db … digest: sha256:437e8772fddeb7e740…
    �[4B�[4A�[2K
    Pulling db … status: image is up to date for o…
    �[4B�[4A�[2K
    Pulling db … �[32mdone�[0m
    �[4B
    �[1A�[2K
    Pulling webapp … pulling from opendronemap/webodm_…
    �[1B�[1A�[2K
    Pulling webapp … digest: sha256:aaeea475b90399d4bd…
    �[1B�[1A�[2K
    Pulling webapp … status: image is up to date for o…
    �[1B
    �[1A�[2K
    Pulling webapp … �[32mdone�[0m
    �[1B
    �[3A�[2K
    Pulling broker … digest: sha256:33ca074e6019b45123…
    �[3B�[3A�[2K
    Pulling broker … status: image is up to date for r…
    �[3B
    �[3A�[2K
    Pulling broker … �[32mdone�[0m
    �[3B
    WebODM has updated. Press Start to launch WebODM
is anyone familiar with this issue?
Mm, deleting the anonymous user might have locked you out, since we use django-guardian. https://stackoverflow.com/questions/46265732/django-i-deleted-anonymoususer-how-to-restore
If a fresh installation is acceptable, you can reset the environment by accessing the docker settings (click the whale icon) and find the “reset to factory defaults” button. This will reset the installation and you’ll be able to start from scratch (but you will lose previous data).
The other approach is trying to restore the anonymous user.
Start WebODM, then launch a Terminal application and type:
docker exec -ti $(docker ps -f name=webapp -q) python manage.py migrate
This will restore the anonymous user. But this is a bit strange, as I was able to log-back in with my admin account after deleting the anonymous user. So there might be something else that caused this and I’m not sure that restoring the anonymous user will fix this.
Thanks for the reply, thats what I have actually done, uninstall and reinstall and it works again
