ODM process result creates really big OBJ files. 330 images process results creates 2GB textured model. Is there a way to create model with less memory. Big models loading is really hard on website.
Thank you
Thank you
Initially resizing your images to half or 1/4 size should reduce the size of the model significantly.
i will try, thank you.
