Hello everybody!
I’ve my gcp_list.txt already in the correct format. For ODM I found out that the should be placed in the base of the processing folder. But how ist the gcp_list.txt loaded for processing in WebODM? Can I load it together with the images?
Thanks for your help, Patrick
You would upload it alongside your images.
So select images and txt file together and load … Thank you!
Let us know how you get on with that set!
Well, it worked this way. Thanks again!
