Running ./webodm.sh start --dev
Live Reload listening on port 35729
is logged
and then shortly after, a series of Live Reload disabled: listen EADDRINUSE :::35729
I’m on macOS High Sierra 10.13.6 and
lsof -nP -i4TCP:35729 | grep LISTEN
doesn’t output anything.
webapp | Setup webpack watch...
webapp | Running migrations
webapp | INFO Initializing GRASS engine using /usr/bin/grass76
webapp | Operations to perform:
webapp | Apply all migrations: admin, app, auth, contenttypes, guardian, nodeodm, sessions
webapp | Running migrations:
webapp | No migrations to apply.
webapp |
webapp | webpack is watching the files…
webapp |
webapp | (node:94) DeprecationWarning: Tapable.plugin is deprecated. Use new API on `.hooks` instead
webapp | Live Reload listening on port 35729
webapp |
webapp | Unlocking Task [Task of 2019-07-10T16:52:08.086Z] (91f58958-0037-4890-b78a-e3e61e57253d)... Already unlocked
webapp | Checking for celery... OK
webapp | /webodm/start.sh: line 80: 125 Killed ./worker.sh scheduler start
webapp | Performing system checks...
webapp |
webapp | INFO Booting WebODM 1.1.0
webapp | WARNING Debug mode is ON (for development this is OK)
webapp | INFO Running webpack with watcher for lightning
webapp | INFO Running webpack with watcher for cesium-ion-webodm-exporter
webapp | INFO Running webpack with watcher for openaerialmap
webapp | INFO Running webpack with watcher for contours
webapp | INFO Running webpack with watcher for measure
webapp | INFO Registered [plugins.lightning.plugin]
webapp | INFO Registered [plugins.cesium-ion-webodm-exporter.plugin]
webapp | INFO Registered [plugins.osm-quickedit.plugin]
webapp | INFO Registered [plugins.openaerialmap.plugin]
webapp | INFO Registered [plugins.diagnostic.plugin]
webapp | INFO Registered [plugins.contours.plugin]
webapp | INFO Registered [plugins.posm-gcpi.plugin]
webapp | INFO Registered [plugins.measure.plugin]
webapp | INFO Registered [plugins.fullscreen.plugin]
webapp | System check identified no issues (0 silenced).
webapp | July 10, 2019 - 18:05:42
webapp | Django version 2.1.9, using settings 'webodm.settings'
webapp | Starting development server at http://0.0.0.0:8000/
webapp | Quit the server with CONTROL-C.
webapp |
webapp | Trying to establish communication...
worker | wait-for-it.sh: webapp:8000 is available after 51 seconds
worker | Checking for celery... OK
worker | Starting worker using broker at redis://broker
webapp |
webapp |
webapp | Live Reload disabled: listen EADDRINUSE :::35729
webapp |
webapp |
webapp |
webapp |
webapp |
webapp |
webapp |
webapp |
worker | INFO Initializing GRASS engine using /usr/bin/grass76
worker | /usr/local/lib/python3.6/site-packages/celery/platforms.py:795: RuntimeWarning: You're running the worker with superuser privileges: this is
worker | absolutely not recommended!
worker |
worker | Please specify a different user using the -u option.
worker |
worker | User information: uid=0 euid=0 gid=0 egid=0
worker |
worker | uid=uid, euid=euid, gid=gid, egid=egid,
worker | /usr/local/lib/python3.6/site-packages/celery/fixups/django.py:202: UserWarning: Using settings.DEBUG leads to a memory leak, never use this setting in production environments!
worker | warnings.warn('Using settings.DEBUG leads to a memory leak, never '
