I have a problem, I have connected my lightning node but the pictures are not sending…
I use the local version on Macbook pro I7
Is there a firewall on your computer that might be blocking the connection?
Check if you can access https://spark1.webodm.net (accessing it from a web browser should give you a “401” error).
You can also always check the status of the network by visiting https://status.webodm.net/
