I downloaded a sample set of images from a photogrammetry vendor of the new DJI Mavic 3 multispectral. I was able to process the ndvi of the ms imagery but it failed when I tried the rgb ortho.
I’m processing with WebODM Lightning. The RGB imagery of the dataset includes 350 images for a total of 3.2 GB. I’m guessing this is something that Lightning can’t handle? Do I need to downsample the images or is there some option that I need to include to run these.
I’m running it again using the lightning node. I’ll capture the logs this time. It’s a very uniform ag field with a kind of vignette thing on the corners of the images. It may just struggle due to lack of diversity in the imagery.
It completed this time but it took 7 hours and 40 minutes. The log is attached. The difference this time is I used the Lightning node instead of the Auto choice. It doesn’t look like I can upload the log file due to not being one of the proper extensions
Even with: min_num_features: 10000, you are typically finding over 100,000 features per image, so I don’t think there is a need to increase that number.
1 partial reconstructions in total
is good
Maybe try on your machine using ultra feature extraction and PC quality?
