Good evening,
When 3D tiles are set to true, the result is a tiled point cloud and a tiled 3D model.
The 3D model has three levels of LOD:
LOD-0
LOD-1
LOD-2
Is there any way to set up more levels? Or make the worst model even worse
Good evening,
LOD-0
LOD-1
LOD-2
AFAIK currently not.
Thanks Piero,
I’ve seen you have been working on giving to 3d model tiles the right geolocation, is it fixed on lightning?
I have updated my windows version but I still get the 3D Tiles geolocated in Italy
Hey Piero, I’ve seen you’ve been working on giving right location to 3D model tiles. Is it fixed? I keep getting wrong location on 3D tiles using lightning.
Also, can be a way to have .glb models correctly geolocated? Or the .obj.
