Child returned 1
File “/code/opendm/types.py”, line 341, in run
File “/code/opendm/types.py”, line 322, in run
File “/code/stages/odm_meshing.py”, line 24, in process
File “/code/opendm/mesh.py”, line 207, in screened_poisson_reconstruction
system.run(’"{reconstructmesh}" -i “{infile}” ’
Looking at your flight plan, I would say a bit more “overfly” over those buildings likely would have helped a lot. The density of images here is a bit variable.
In looking at your images, I’m seeing that they are slightly over-exposed if your focal point was the buildings instead of the field/forest around them. You’re getting highly-spectral surfaces which are hard to reconstruct:
