Launching WebODM
Just installed WebODM. It will start to launch but not open. I am on Windows 10 and I just updated as well. Does anyone have an idea what the problem would be?
LOG: database system was shut down at 2021-09-28 14:33:14 EDT
LOG: MultiXact member wraparound protections are now enabled
LOG: database system is ready to accept connections
LOG: autovacuum launcher started
FATAL: relation mapping file “global/pg_filenode.map” contains invalid data
LOG: autovacuum launcher process (PID 4744) exited with exit code 1
LOG: terminating any other active server processes
LOG: all server processes terminated; reinitializing
LOG: database system was interrupted; last known up at 2021-10-04 19:34:57 EDT
LOG: database system was not properly shut down; automatic recovery in progress
LOG: invalid record length at 0/E1D96A0: wanted 24, got 0
LOG: redo is not required
LOG: autovacuum launcher process (PID 14860) exited with exit code 1
LOG: invalid record length at 0/E1D9710: wanted 24, got 0
FATAL: the database system is in recovery mode
LOG: autovacuum launcher process (PID 10008) exited with exit code 1
LOG: invalid record length at 0/E1D9780: wanted 24, got 0
LOG: autovacuum launcher process (PID 4976) exited with exit code 1
LOG: invalid record length at 0/E1D97F0: wanted 24, got 0
LOG: autovacuum launcher process (PID 5224) exited with exit code 1
LOG: invalid record length at 0/E1D9860: wanted 24, got 0
LOG: autovacuum launcher process (PID 14840) exited with exit code 1
LOG: invalid record length at 0/E1D98D0: wanted 24, got 0
LOG: autovacuum launcher process (PID 13088) exited with exit code 1
LOG: invalid record length at 0/E1D9940: wanted 24, got 0
LOG: invalid record length at 0/E1D99B0: wanted 24, got 0
LOG: autovacuum launcher process (PID 8296) exited with exit code 1
LOG: invalid record length at 0/E1D9A20: wanted 24, got 0
LOG: autovacuum launcher process (PID 8656) exited with exit code 1
LOG: invalid record length at 0/E1D9A90: wanted 24, got 0
LOG: autovacuum launcher process (PID 13004) exited with exit code 1
LOG: database system was interrupted; last known up at 2021-10-04 19:34:58 EDT
LOG: invalid record length at 0/E1D9B00: wanted 24, got 0
LOG: autovacuum launcher process (PID 12520) exited with exit code 1
LOG: invalid record length at 0/E1D9B70: wanted 24, got 0
LOG: autovacuum launcher process (PID 4996) exited with exit code 1
LOG: invalid record length at 0/E1D9BE0: wanted 24, got 0
LOG: autovacuum launcher process (PID 2020) exited with exit code 1
LOG: invalid record length at 0/E1D9C50: wanted 24, got 0
LOG: autovacuum launcher process (PID 15148) exited with exit code 1
LOG: invalid record length at 0/E1D9CC0: wanted 24, got 0
LOG: autovacuum launcher process (PID 11984) exited with exit code 1
LOG: invalid record length at 0/E1D9D30: wanted 24, got 0
LOG: autovacuum launcher process (PID 12020) exited with exit code 1
LOG: invalid record length at 0/E1D9DA0: wanted 24, got 0
LOG: autovacuum launcher process (PID 9620) exited with exit code 1
LOG: invalid record length at 0/E1D9E10: wanted 24, got 0
LOG: autovacuum launcher process (PID 11932) exited with exit code 1
LOG: invalid record length at 0/E1D9E80: wanted 24, got 0
LOG: autovacuum launcher process (PID 4564) exited with exit code 1
LOG: database system was interrupted; last known up at 2021-10-04 19:34:59 EDT
LOG: invalid record length at 0/E1D9EF0: wanted 24, got 0
LOG: autovacuum launcher process (PID 7548) exited with exit code 1
LOG: invalid record length at 0/E1D9F60: wanted 24, got 0
LOG: autovacuum launcher process (PID 9336) exited with exit code 1
LOG: invalid record length at 0/E1D9FD0: wanted 24, got 0
LOG: autovacuum launcher process (PID 15092) exited with exit code 1
LOG: invalid record length at 0/E1DA058: wanted 24, got 0
LOG: autovacuum launcher process (PID 1964) exited with exit code 1
LOG: invalid record length at 0/E1DA0C8: wanted 24, got 0
LOG: autovacuum launcher process (PID 12480) exited with exit code 1
LOG: invalid record length at 0/E1DA138: wanted 24, got 0
LOG: autovacuum launcher process (PID 12144) exited with exit code 1
LOG: invalid record length at 0/E1DA1A8: wanted 24, got 0
LOG: autovacuum launcher process (PID 13264) exited with exit code 1
LOG: invalid record length at 0/E1DA218: wanted 24, got 0
LOG: autovacuum launcher process (PID 12996) exited with exit code 1
LOG: invalid record length at 0/E1DA288: wanted 24, got 0
LOG: autovacuum launcher process (PID 10988) exited with exit code 1
LOG: invalid record length at 0/E1DA2F8: wanted 24, got 0
LOG: autovacuum launcher process (PID 6772) exited with exit code 1
LOG: database system was interrupted; last known up at 2021-10-04 19:35:00 EDT
LOG: invalid record length at 0/E1DA368: wanted 24, got 0
LOG: invalid record length at 0/E1DA3D8: wanted 24, got 0
LOG: autovacuum launcher process (PID 8532) exited with exit code 1
LOG: invalid record length at 0/E1DA448: wanted 24, got 0
LOG: autovacuum launcher process (PID 13008) exited with exit code 1
LOG: invalid record length at 0/E1DA4B8: wanted 24, got 0
LOG: autovacuum launcher process (PID 15088) exited with exit code 1
LOG: invalid record length at 0/E1DA528: wanted 24, got 0
LOG: autovacuum launcher process (PID 12472) exited with exit code 1
LOG: invalid record length at 0/E1DA598: wanted 24, got 0
LOG: autovacuum launcher process (PID 11112) exited with exit code 1
LOG: invalid record length at 0/E1DA608: wanted 24, got 0
LOG: autovacuum launcher process (PID 7880) exited with exit code 1
LOG: invalid record length at 0/E1DA678: wanted 24, got 0
LOG: autovacuum launcher process (PID 15004) exited with exit code 1
LOG: invalid record length at 0/E1DA6E8: wanted 24, got 0
LOG: autovacuum launcher process (PID 9960) exited with exit code 1
LOG: invalid record length at 0/E1DA758: wanted 24, got 0
