Hi All,
I am working on processing a 92,000 image dataset using split-merge, 72 cores, and 1.5 TB of RAM (across 6 hosts, although half the compute capacity is on one host alone). Needless to say, I am learning a lot.
As I am doing this, there are some peculiarities to the process: it’s predominantly not RTK data, it’s 4 different cameras (which is super helpful for lens correction), and we are working toward one seamless product, both elevation model and orthophoto.
I have been searching for equivalent projects. DroneDeploy proudly announced a while back the capacity to do 10k image datasets. Searching the Pix4D forums, I find some references to some 30k image datasets (which I have crossed that threshold on a previous project), but I am not seeing anything larger than 30k.
So, my question to all of you: have you seen anything larger than 92k images (roughly 1800 gigapixels of imagery) regardless of software (Pix4D, Agisoft, etc.) for producing a seamless product?
And if not: what’s the largest you have encountered?
BTW: and yes, I will be sharing what I learn in this project in the docs.
I think DroneDeploy did a story on processing 70k images, but I don’t think this was merged as a single product. They mention that “The next day the data was delivered in 75 maps”. https://medium.com/aerial-acuity/supporting-the-relief-efforts-of-californias-most-destructive-wildfire-from-above-7c50c1128108
So seems like they just run ~1,000 images per batch (maybe due to timing constraints, given the emergency situation).
Well, it certainly would scale horizontally very nicely that way. Also, I think we were the first to use a split-merge type approach: even Agisoft and Pix4D came out with a split-merge solution after us.
But this is helpful, and pretty similar other than the merging portion. Classic crisis mapping too: 75 maps was good enough and faster to do, so just get it done.
How in the world did you get 1.5TB, even across six hosts???
When you buy instead of rent, you can do a lot more…
No, I’m wondering how you physically address that much memory, even across 6 hosts? Must be a new motherboard I’ve not heard of.
1.5 TB / 6 = 256 GB
I think that’s well within normal server specs.
I did not switch mental gears into server territory. Silly me.
Back to the drawing board…
Yeah, getting that in a laptop or desktop would be unusual. But server motherboards commonly can support a fair amount of RAM.
When you get to those system levels, desktop systems seem puny. 3 of my workstations (my NodeODM nodes) max out at 1 TB RAM (that’ll take a lot of money!) and my WebODM, soon to be ClusterODM workstation maxes out at 2 TB. These are older used systems, that are out dated by today’s standards.
The differences with the desktop world are quite stark these days.
