Hope my question is not silly and helpful for others also.
Does any of you have an idea about the ext4 file?
which is located following directory, C:\Users\paul\AppData\Local\Docker\wsl\data
Currently, I have actively run WebODM with Lightning Node.
I subscribed to Lightning ODM because the storage of my device was not enough
And I just realized whenever I run the process, a large portion of SSD has been taken.
I found ext4 file itself takes 107GB, making my laptop so slow.
Is it usual for using Lightning WebODM? and if I delete this file, will there be any problem with running docker and Lightning WebODM?
By the way, although I use Lightning WebODM, I still need to run it in the desktop app for 2D map and 3D model viewer for my research.
