Hi OpenDroneMap!
We are trying to creating DSM using ODM in docker, we are using Large format aircraft images which are around 60% overlapping for two continues aquisition. There are some areas only have two images ovelapped so they are generating wired patterns(just like I marked in the red box, the yellow boxes are image footprint)
We have found some discussion in the forum https://community.opendronemap.org/t/minimum-number-of-overlapping-images-for-point-cloud-generation/514/5?u=meigeo and changed depthmap_min_consistent_views
to 2 in OpenDroneMap/SuperBuild/src/opensfm/opensfm/config.py. but we got the same result
Below I put a link include 4 sample images and EO parameters
https://drive.google.com/drive/folders/1I8mxA21QnqpFIgjTvDP6oQo8wRr5XOJ2?usp=sharing
Do you have any idea if it is possible to generate DSM with two stereo images? Or
do we need to change some other parameters?
Best regards,
Yi
