Hi all. Looking for a little guidance. I’m trying to run a fairly large data set, 5000 pictures (3MB each-ish, 4000 x 3000 pixels). I’m running WebODM through docker on Windows 10 on a Ryzen 3900X so 24 threads with 128GB RAM. I’ve set docker to use 115GB of RAM (anymore and I get errors in the processing, probably because Windows then doesn’t have enough RAM). Set my swap to 240GB. I’m running the GPU build of WebODM to speed things up a little with my RTX 2070 Super.
Running the dataset with these options:
auto-boundary:true, dsm:true, matcher-neighbors:20, mesh-size:300000, min-num-features:30000, verbose:true
I had increased the min-num-features because my overlap isn’t great, probably around 30%. I’m basically trying to map a large area (2,000 hectares).
The processing completes the opensfm phase and then starts the openmvs stage. I get:
[INFO] Estimating depthmaps
[INFO] running "/code/SuperBuild/install/bin/OpenMVS/DensifyPointCloud" "/var/www/data/20dbdc88-89c7-461e-9bf5-cc88beb5def5/opensfm/undistorted/openmvs/scene.mvs" --resolution-level 3 --min-resolution 500 --max-resolution 4000 --max-threads 24 --number-views-fuse 2 -w "/var/www/data/20dbdc88-89c7-461e-9bf5-cc88beb5def5/opensfm/undistorted/openmvs/depthmaps" -v 0 --geometric-iters 0
At which point I got to just over 400hrs (17 days) of total processing and then my virtual drive in docker maxes out at the 1.5TB I had set it to (never thinking it would use all that space). Docker crashes and I have to wipe it and start from scratch. My RAM usage is fine, the swap only ever hits 30GB.
So my question is, is it normal to take that much time (400hrs) and use that much space (1.5TB) just up to the openmvs stage? With my low overlap, is it worth doing a 3D model (or even possible) or just skipping it and setting fast-orthophoto True
? The 3D model would be nice to have but not necessary.
I’m thinking of deleting every other picture to drop the total number down to 2,500 if that helps. Or maybe split the pictures into batches and then process them separately?
Open to any suggestions to speed this up and have it complete on me!
