Key point coordinates
Hi everyone,
I am new to the forum and new in the use of WebODM.
I am particularly interested into have the coordinates of the key points ODM use to stitch the images. I come from Metashape where you can easily obtain a txt file with coordinates of tie points. Assuming, but I am not 100% sure that’s right, that metashape tie points and ODM key points are the same can I obtain this information?
matteo
This is a great question!
What would you use the data for?
I’m not sure we can generate this… Perhaps Piero or Stephen may know better.
Hi, thanks for your reply.
I would use the points to analyse the variation of the pixel values corresponding to the key point in subsequent images and as function of its distance to the centroid of the image…
Hope is going to be possible to do so…
