We’re releasing new changes to ODM and WebODM to display camera positions, for both the map and 3D display, with thumbnails support for both geo and non-geo datasets. WebODM now can also prepare a cup of coffee for you. Kiddin’ (would be awesome though).
I recently discovered this feature and it is a great add! Thank you!!! It is proving useful in several ways, including debugging.
On a related note…and maybe a separate topic…I have discovered some inconsistency in the shown camera position (cameras are displayed as inverted, rotated, and offset in altitude w.r.t. the position of the actual image/collection position). This appears to be correlated / leading to high levels of distortion, missing sections, and gps offsets in the ortho and 3D outputs. Any idea why/how this might be happening and any settings to help correct?
I think it’s worth a new thread so the question doesn’t get buried. If you can share a dataset to help reproduce that would be helpful. I haven’t looked closely at camera position accuracy, myself, but others should be able to help locate the issue.
