I am very new to this and desperately want to learn it.
The vocabulary is daunting as well to learn.
I am doing a project to map cemeteries. No matter how I set the drone up to fly them nor how much I overlap the sides I still end up with not all of the cemetery or not enough to crop it square in Lightroom.
I fly a Mavic2 Zoom with Pilot PE in a Smart controller. It takes the photos that appear to be the ones that are needed. Instead of process a square finished picture in ODM I end up with an area o one end that is egg shaped or oval shaped. The part it does is great. I just can not get ODM to produce the area I need.
I am using a MacBook Pro. Catalina 10.5.7
2.6 GHz 6-Core Intel Core i7
16 GB 2667 MHz DDR4
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
I am getting no errors.
I am processing less than 300 photos.
Here is a link to one I have had issues with.
The bottom right of this one should be larger. It should be more square instead of egg shaped on the right.
thanks.
