Installed WebODM as per instructions on Linux Mint. Upon trying to start the program I get this error.
john@john-Lenovo-3000-G530:~/WebODM$ ./webodm.sh start
Checking for docker… OK
Checking for git… OK
Starting WebODM…
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
ERROR: Couldn’t connect to Docker daemon at http+docker://localhost - is it running?
If it’s at a non-standard location, specify the URL with the DOCKER_HOST environment variable.
Any help would be appreciated. I’m a noob
