Issues with code 1 failure - tried seweral options with no luck
Can’t seem to figure out why I keep getting the code 1 error. If I only select fast orthophoto it will run fine. Anything else and I generally get code 1 after an hour or two. I’ve adjusted the min-num-features option a few times with no changes. It’s a fairly small dataset (93 photos) taken with a DJI phantom 4. No GCPs. I know that this has been almost beat to death, but I haven’t found a solution that helps me out.
link to photos
https://drive.google.com/drive/folders/1TS7pyyQkKGB6jRmOV4CeApXo0v0rUPK6?usp=sharing
output
… output truncated at 500 lines …
Processing view view_0030.mve…
Processing view view_0031.mve…
Processing view view_0032.mve…
Processing view view_0033.mve…
Processing view view_0034.mve…
Processing view view_0035.mve…
Processing view view_0036.mve…
Processing view view_0037.mve…
Processing view view_0038.mve…
Processing view view_0039.mve…
Processing view view_0040.mve…
Processing view view_0041.mve…
Processing view view_0042.mve…
Processing view view_0043.mve…
Processing view view_0044.mve…
Processing view view_0045.mve…
Processing view view_0046.mve…
Processing view view_0047.mve…
Processing view view_0048.mve…
Processing view view_0049.mve…
Processing view view_0050.mve…
Processing view view_0051.mve…
Processing view view_0052.mve…
Processing view view_0053.mve…
Processing view view_0054.mve…
Processing view view_0055.mve…
Processing view view_0056.mve…
Processing view view_0057.mve…
Processing view view_0058.mve…
Processing view view_0059.mve…
Processing view view_0060.mve…
Processing view view_0061.mve…
Processing view view_0062.mve…
Processing view view_0063.mve…
Processing view view_0064.mve…
Processing view view_0065.mve…
Processing view view_0066.mve…
Processing view view_0067.mve…
Processing view view_0068.mve…
Processing view view_0069.mve…
Processing view view_0070.mve…
Processing view view_0071.mve…
Processing view view_0072.mve…
Processing view view_0073.mve…
Processing view view_0074.mve…
Processing view view_0075.mve…
Processing view view_0076.mve…
Processing view view_0077.mve…
Processing view view_0078.mve…
Processing view view_0079.mve…
Processing view view_0080.mve…
Processing view view_0081.mve…
Processing view view_0082.mve…
Processing view view_0083.mve…
Skipping
view_0083.mve
: Invalid camera.
Processing view view_0084.mve…
Processing view view_0085.mve…
Processing view view_0086.mve…
Processing view view_0087.mve…
Processing view view_0088.mve…
Processing view view_0089.mve…
Processing view view_0090.mve…
Processing view view_0091.mve…
Processing view view_0092.mve…
Created 93 views with 92 valid cameras.
Imported 92 undistorted images.
[DEBUG] running /code/SuperBuild/src/elibs/smvs/app/smvsrecon -t2 -a1.0 --max-pixels=409600 -o1 --debug-lvl=0 --force /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/smvs
Shading-aware Multi-view Stereo (built on Jan 29 2019, 15:57:26)
Initializing scene with 92 views…
Initialized 92 views (max ID is 92), took 10ms.
Reading Photosynther file (93 cameras, 140112 features)…
Automatic input scale: 2
Input embedding: undist-L2
Output embedding: smvs-B2
Running view selection for 92 views…
done, took 39.211s.
Resizing input images for 92 views…
done, took 18.677s.
Starting 1/92 ID: 0 Neighbors: 4 6 26 18 23 36
Starting 2/92 ID: 1 Neighbors: 10 28 80 54 74 75
Finished 1/92 ID: 0
Starting 3/92 ID: 2 Neighbors: 84 17 64 52 87 24
Finished 2/92 ID: 1
Starting 4/92 ID: 3 Neighbors: 67 92 7 68 61 31
Finished 3/92 ID: 3
Starting 5/92 ID: 4 Neighbors: 34 0 18 44 82 36
Finished 4/92 ID: 2
Starting 6/92 ID: 5 Neighbors: 41 49 45 37 58 46
Finished 5/92 ID: 4
Finished 6/92 ID: 5
Starting 7/92 ID: 6 Neighbors: 30 0 77 50 23 26
Starting 8/92 ID: 7 Neighbors: 61 31 55 9 3 47
Finished 7/92 ID: 7
Starting 9/92 ID: 8 Neighbors: 85 79 59 53 25 20
Finished 8/92 ID: 6
Starting 10/92 ID: 9 Neighbors: 60 47 7 87 31 89
Finished 9/92 ID: 9
Starting 11/92 ID: 10 Neighbors: 1 28 80 75 62 54
Finished 10/92 ID: 8
Starting 12/92 ID: 11 Neighbors: 39 71 75 10 24 90
Finished 11/92 ID: 10
Starting 13/92 ID: 12 Neighbors: 61 76 48 70 7 92
Finished 12/92 ID: 11
Starting 14/92 ID: 13 Neighbors: 29 43 74 51 72 15
Finished 13/92 ID: 12
Starting 15/92 ID: 14 Neighbors: 32 90 91 63 33 75
Finished 14/92 ID: 13
Starting 16/92 ID: 15 Neighbors: 54 51 77 74 28 88
Finished 15/92 ID: 14
Starting 17/92 ID: 16 Neighbors: 27 66 73 68 58 67
Finished 16/92 ID: 15
Starting 18/92 ID: 17 Neighbors: 52 64 76 2 87 24
Finished 17/92 ID: 16
Starting 19/92 ID: 18 Neighbors: 26 82 4 72 86 0
Finished 18/92 ID: 17
Starting 20/92 ID: 19 Neighbors: 42 50 30 25 59 23
Finished 19/92 ID: 18
Starting 21/92 ID: 20 Neighbors: 25 37 42 85 49 8
Finished 20/92 ID: 19
Starting 22/92 ID: 21 Neighbors: 46 68 92 45 48 58
Finished 21/92 ID: 20
Starting 23/92 ID: 22 Neighbors: 40 88 80 62 54 59
Finished 22/92 ID: 21
Starting 24/92 ID: 23 Neighbors: 36 50 0 6 4 19
Finished 23/92 ID: 22
Starting 25/92 ID: 24 Neighbors: 71 52 33 17 39 90
Finished 24/92 ID: 23
Starting 26/92 ID: 25 Neighbors: 20 42 19 37 8 59
Finished 25/92 ID: 24
Starting 27/92 ID: 26 Neighbors: 18 77 51 0 88 4
Finished 26/92 ID: 25
Starting 28/92 ID: 27 Neighbors: 58 16 68 41 73 21
Finished 27/92 ID: 26
Starting 29/92 ID: 28 Neighbors: 1 74 10 54 15 13
Finished 28/92 ID: 27
Starting 30/92 ID: 29 Neighbors: 43 13 72 51 74 38
Finished 29/92 ID: 28
Starting 31/92 ID: 30 Neighbors: 6 59 19 88 77 50
Finished 30/92 ID: 29
Starting 32/92 ID: 31 Neighbors: 55 7 67 60 9 3
Finished 31/92 ID: 30
Starting 33/92 ID: 32 Neighbors: 14 62 53 75 90 40
Finished 32/92 ID: 31
Starting 34/92 ID: 33 Neighbors: 70 90 76 24 71 14
Finished 33/92 ID: 32
Starting 35/92 ID: 34 Neighbors: 44 4 82 86 65 69
Finished 34/92 ID: 33
Starting 36/92 ID: 35 Neighbors: 48 63 45 46 92 12
Finished 35/92 ID: 34
Starting 37/92 ID: 36 Neighbors: 23 4 0 65 69 50
Finished 36/92 ID: 35
Starting 38/92 ID: 37 Neighbors: 49 20 5 25 79 57
Finished 37/92 ID: 36
Starting 39/92 ID: 38 Neighbors: 81 72 82 86 78 56
Finished 38/92 ID: 37
Starting 40/92 ID: 39 Neighbors: 11 71 75 24 90 33
Finished 39/92 ID: 38
Starting 41/92 ID: 40 Neighbors: 22 53 62 80 88 32
Finished 40/92 ID: 39
Starting 42/92 ID: 41 Neighbors: 5 58 49 46 45 21
Finished 41/92 ID: 40
Starting 43/92 ID: 42 Neighbors: 25 19 59 20 30 8
Finished 42/92 ID: 41
Starting 44/92 ID: 43 Neighbors: 29 13 72 38 51 74
Finished 43/92 ID: 42
Starting 45/92 ID: 44 Neighbors: 34 86 56 78 82 69
Finished 44/92 ID: 43
Starting 46/92 ID: 45 Neighbors: 46 57 35 21 63 48
Finished 45/92 ID: 44
Starting 47/92 ID: 46 Neighbors: 45 21 48 35 57 92
Finished 46/92 ID: 45
Starting 48/92 ID: 47 Neighbors: 76 9 61 64 70 7
Finished 47/92 ID: 46
Starting 49/92 ID: 48 Neighbors: 35 92 46 12 63 45
Finished 48/92 ID: 47
Starting 50/92 ID: 49 Neighbors: 5 37 41 57 20 45
Finished 49/92 ID: 48
Starting 51/92 ID: 50 Neighbors: 23 19 6 36 30 0
Finished 50/92 ID: 49
Starting 52/92 ID: 51 Neighbors: 72 15 26 13 74 29
Finished 51/92 ID: 50
Starting 53/92 ID: 52 Neighbors: 17 24 70 76 64 84
Finished 52/92 ID: 51
Starting 54/92 ID: 53 Neighbors: 40 91 85 32 8 79
Finished 53/92 ID: 52
Starting 55/92 ID: 54 Neighbors: 15 80 88 28 77 1
Finished 54/92 ID: 53
Starting 56/92 ID: 55 Neighbors: 31 7 67 60 9 3
Finished 55/92 ID: 54
Starting 57/92 ID: 56 Neighbors: 78 86 44 82 81 34
Finished 56/92 ID: 55
Starting 58/92 ID: 57 Neighbors: 45 79 63 46 49 35
Finished 57/92 ID: 56
Starting 59/92 ID: 58 Neighbors: 41 27 5 21 46 68
Finished 58/92 ID: 57
Starting 60/92 ID: 59 Neighbors: 30 42 8 22 19 85
Finished 59/92 ID: 58
Starting 61/92 ID: 60 Neighbors: 9 31 55 89 87 7
Finished 60/92 ID: 59
Starting 62/92 ID: 61 Neighbors: 12 7 47 92 3 76
Finished 61/92 ID: 60
Starting 63/92 ID: 62 Neighbors: 80 32 40 22 54 10
Finished 62/92 ID: 61
Starting 64/92 ID: 63 Neighbors: 35 91 57 45 48 14
Finished 63/92 ID: 62
Starting 65/92 ID: 64 Neighbors: 87 17 89 47 9 52
Finished 64/92 ID: 63
Starting 66/92 ID: 65 Neighbors: 69 44 34 36 4 86
Finished 65/92 ID: 64
Starting 67/92 ID: 66 Neighbors: 73 67 68 3 16 31
Finished 66/92 ID: 65
Starting 68/92 ID: 67 Neighbors: 3 31 55 73 66 7
Finished 67/92 ID: 66
Starting 69/92 ID: 68 Neighbors: 21 73 3 66 92 46
Finished 68/92 ID: 67
Starting 70/92 ID: 69 Neighbors: 65 44 34 36 4 86
Finished 69/92 ID: 68
Starting 71/92 ID: 70 Neighbors: 76 33 47 12 52 90
Finished 70/92 ID: 69
Starting 72/92 ID: 71 Neighbors: 24 39 90 11 52 33
Finished 71/92 ID: 70
Starting 73/92 ID: 72 Neighbors: 38 51 18 29 43 82
Finished 72/92 ID: 72
Starting 74/92 ID: 73 Neighbors: 66 68 67 3 16 31
Finished 73/92 ID: 71
Starting 75/92 ID: 74 Neighbors: 28 13 15 51 29 1
Finished 74/92 ID: 73
Starting 76/92 ID: 75 Neighbors: 90 32 39 10 11 33
Finished 75/92 ID: 74
Starting 77/92 ID: 76 Neighbors: 70 47 12 33 17 61
Finished 76/92 ID: 75
Starting 78/92 ID: 77 Neighbors: 88 26 15 6 18 54
Finished 77/92 ID: 76
Starting 79/92 ID: 78 Neighbors: 56 86 81 44 82 38
Finished 78/92 ID: 77
Starting 80/92 ID: 79 Neighbors: 85 57 8 91 37 45
Finished 79/92 ID: 78
Starting 81/92 ID: 80 Neighbors: 62 54 22 10 1 15
Finished 80/92 ID: 79
Starting 82/92 ID: 81 Neighbors: 38 86 78 56 82 72
Finished 81/92 ID: 80
Starting 83/92 ID: 82 Neighbors: 86 18 34 38 56 78
Finished 82/92 ID: 81
Starting 84/92 ID: 84 Neighbors: 2 52 17 24 64 87
Finished 83/92 ID: 82
Starting 85/92 ID: 85 Neighbors: 8 79 53 20 59 91
Finished 84/92 ID: 84
Starting 86/92 ID: 86 Neighbors: 56 78 82 44 81 34
Finished 85/92 ID: 85
Starting 87/92 ID: 87 Neighbors: 89 64 9 60 17 47
Finished 86/92 ID: 86
Starting 88/92 ID: 88 Neighbors: 77 22 54 15 30 26
Finished 87/92 ID: 87
Starting 89/92 ID: 89 Neighbors: 87 64 60 9 47 17
Finished 88/92 ID: 88
Starting 90/92 ID: 90 Neighbors: 33 75 14 71 70 32
Finished 89/92 ID: 89
Starting 91/92 ID: 91 Neighbors: 63 53 79 14 57 35
Finished 90/92 ID: 90
Starting 92/92 ID: 92 Neighbors: 48 3 21 61 35 12
Finished 91/92 ID: 91
Finished 92/92 ID: 92
Saving views to MVE files… done.
Done. Reconstruction took: 3447.59s
Generating Pointcloud, Cutting surfaces for 92 views …
Done. Took: 148.866s
Writing PLY file (14562362 verts, with colors, with normals, with confidences, with values, 0 faces)…
done.
[INFO] Running ODM SMVS Cell - Finished
[INFO] Running ODM Meshing Cell
[DEBUG] Writing ODM Mesh file in: /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_meshing/odm_mesh.ply
[DEBUG] running /code/SuperBuild/src/PoissonRecon/Bin/Linux/PoissonRecon --in /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/smvs/smvs_dense_point_cloud.ply --out /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_meshing/odm_mesh.dirty.ply --depth 9 --pointWeight 4 --samplesPerNode 1.0 --threads 2 --linearFit
[DEBUG] running /code/build/bin/odm_cleanmesh -inputFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_meshing/odm_mesh.dirty.ply -outputFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_meshing/odm_mesh.ply -removeIslands -decimateMesh 100000
[DEBUG] Writing ODM 2.5D Mesh file in: /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_meshing/odm_25dmesh.ply
[DEBUG] ODM 2.5D DSM resolution: 0.25735
[INFO] Created temporary directory: /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_meshing/tmp
[INFO] Creating …/var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_meshing/tmp/mesh_dsm_r0.363947860277 [max] from 1 files
[DEBUG] running pdal pipeline -i /tmp/tmpxxdLSY.json > /dev/null 2>&1
[INFO] Completed …/var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_meshing/tmp/mesh_dsm_r0.363947860277 [max] in 0:01:34.773474
[INFO] Starting gap-filling with nearest interpolation…
[INFO] Completed gap-filling to create …/var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_meshing/tmp/mesh_dsm.tif in 0:00:09.465091
[INFO] Creating mesh from DSM: /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_meshing/tmp/mesh_dsm.tif
[DEBUG] running /code/SuperBuild/src/dem2mesh/dem2mesh -inputFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_meshing/tmp/mesh_dsm.tif -outputFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_meshing/odm_25dmesh.ply -maxVertexCount 100000
[INFO] Running ODM Meshing Cell - Finished
[INFO] Running MVS Texturing Cell
[DEBUG] Writing MVS Textured file in: /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_texturing/odm_textured_model.obj
[DEBUG] running /code/SuperBuild/install/bin/texrecon /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/opensfm/reconstruction.nvm /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_meshing/odm_mesh.ply /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_texturing/odm_textured_model -d gmi -o gauss_clamping -t none -n 65535
/code/SuperBuild/install/bin/texrecon (built on Jan 29 2019, 15:32:02)
Load and prepare mesh:
Reading PLY: 85543 verts…
170138 faces…
done.
Warning: Zero-length normals detected: 2 face normals, 405 vertex normals
Generating texture views:
NVM: Loading file…
NVM: Number of features: 0
Loading 100%… done. (Took 51.066s)
Building adjacency graph:
Adding edges 100%… done. (Took 0.655s)
255139 total edges.
View selection:
Building BVH from 170138 faces…
done. (Took: 656 ms)
Calculating face qualities 100%… done. (Took 32.867s)
Postprocessing face infos 100%… done. (Took 1.725s)
Maximum quality of a face within an image: 1110.93
Clamping qualities to 186.21 within normalization.
Writing data cost file…
done.
Optimizing:
Time[s] Energy
0 149158
1 144707
2 142576
3 141431
3 140932
4 140571
4 140385
6 140207
6 140073
7 139997
7 139940
8 139889
8 139836
9 139784
10758 faces have not been seen
Took: 45.395s
Generating texture patches:
Running…
done. (Took 12.859s)
267 texture patches.
Running global seam leveling:
done.
Lhs dimensionality: 86893 x 86893
Calculating adjustments:
Color channel 0: CG took 76 iterations. Residual is 8.92067e-05
Color channel 2: CG took 76 iterations. Residual is 8.95112e-05
Color channel 1: CG took 76 iterations. Residual is 8.89889e-05
Took 0.506 seconds
Adjusting texture patches 100%… done. (Took 4.102s)
Running local seam leveling:
Blending texture patches 100%… done. (Took 52.599s)
Generating texture atlases:
Sorting texture patches…
done.
Working on atlas 6 100%… done.
Finalizing texture atlases…
done. (Took: 10.809s)
Building objmodel:
Saving model…
done.
Whole texturing procedure took: 202.793s
[DEBUG] Writing MVS Textured file in: /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_texturing_25d/odm_textured_model.obj
[DEBUG] running /code/SuperBuild/install/bin/texrecon /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/opensfm/reconstruction.nvm /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_meshing/odm_25dmesh.ply /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_texturing_25d/odm_textured_model -d gmi -o gauss_clamping -t none --nadir_mode -n 65535
Reading PLY: 100215 verts…
200000 faces…
done.
Warning: Zero-length normals detected: 2 face normals, 0 vertex normals
NVM: Loading file…
Loading 100%… done. (Took 46.765s)
Adding edges 100%… done. (Took 0.788s)
299786 total edges.
View selection:
Building BVH from 200000 faces…
done. (Took: 629 ms)
Calculating face qualities 100%… done. (Took 31.245s)
Postprocessing face infos 100%… done. (Took 1.037s)
Maximum quality of a face within an image: 2916.1
Clamping qualities to 572.488 within normalization.
done.
Optimizing:
Time[s] Energy
0 198287
5 197293
5 195635
6 194755
6 194325
7 194077
7 193933
12 193793
13 193731
13 193687
14 193638
14 193600
15 193577
81180 faces have not been seen
Took: 50.321s
Running…
done. (Took 12.705s)
1541 texture patches.
done.
Lhs dimensionality: 68695 x 68695
Color channel 2: CG took 79 iterations. Residual is 9.64558e-05
Color channel 0: CG took 79 iterations. Residual is 8.86415e-05
Color channel 1: CG took 79 iterations. Residual is 9.27089e-05
Took 0.402 seconds
Adjusting texture patches 100%… done. (Took 5.617s)
Blending texture patches 100%… done. (Took 58.521s)
done.
done. (Took: 19.547s)
Building objmodel:
Saving model…
done.
Whole texturing procedure took: 219.344s
[INFO] Running georeferencing with OpenSfM transformation matrix
[DEBUG] running /code/build/bin/odm_georef -bundleFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/opensfm/bundle_r000.out -inputTransformFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/opensfm/geocoords_transformation.txt -inputCoordFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/coords.txt -inputFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_texturing/odm_textured_model.obj -outputFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_texturing/odm_textured_model_geo.obj -inputPointCloudFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/smvs/smvs_dense_point_cloud.ply -outputPointCloudFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/odm_georeferenced_model.laz -outputPointCloudSrs '+units=m +no_defs=True +datum=WGS84 +proj=utm +zone=16 ’ -logFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/odm_georeferencing_log.txt -outputTransformFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/odm_georeferencing_transform.txt -georefFileOutputPath /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/odm_georeferencing_model_geo.txt
[INFO] Calculating cropping area and generating bounds shapefile from point cloud
[DEBUG] running pdal translate -i “/var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/odm_georeferenced_model.laz” -o “/var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/odm_georeferenced_model.filtered.las” decimation outlier range --filters.decimation.step=90 --filters.outlier.method=radius --filters.outlier.radius=2 --filters.outlier.min_k=2 --filters.range.limits=‘Classification![7:7]’
[DEBUG] running pdal info --boundary --filters.hexbin.edge_length=1 --filters.hexbin.threshold=0 /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/odm_georeferenced_model.filtered.las > /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/odm_georeferenced_model.boundary.json
[DEBUG] running pdal info --summary /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/odm_georeferenced_model.laz > /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/odm_georeferenced_model.summary.json
[DEBUG] running ogr2ogr -overwrite -a_srs “+proj=utm +zone=16 +datum=WGS84 +units=m +no_defs” /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/odm_georeferenced_model.bounds.shp /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/odm_georeferenced_model.bounds.geojson
[DEBUG] running /code/build/bin/odm_georef -bundleFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/opensfm/bundle_r000.out -inputTransformFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/opensfm/geocoords_transformation.txt -inputCoordFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/coords.txt -inputFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_texturing_25d/odm_textured_model.obj -outputFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_texturing_25d/odm_textured_model_geo.obj -logFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_25dgeoreferencing/odm_georeferencing_log.txt -outputTransformFile /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_25dgeoreferencing/odm_georeferencing_transform.txt -georefFileOutputPath /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_25dgeoreferencing/odm_georeferencing_model_geo.txt
[INFO] Running ODM Georeferencing Cell - Finished
[INFO] Running ODM DEM Cell
[INFO] Classify: True
[INFO] Create DSM: True
[INFO] Create DTM: True
[INFO] DEM input file /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/odm_georeferenced_model.laz found: True
[INFO] Classifying /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/odm_georeferenced_model.laz using smrf
[DEBUG] running pdal translate -i /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/odm_georeferenced_model.laz -o /var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/odm_georeferenced_model.laz smrf --filters.smrf.cell=2 --filters.smrf.slope=10 --filters.smrf.window=10
[INFO] Created …/var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_georeferencing/odm_georeferenced_model.laz in 0:01:03.433838
[WARNING] Maximum resolution set to GSD - -300% (20.59 cm / pixel, requested resolution was 5.0 cm / pixel)
[INFO] Creating …/var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_dem/dsm_r0.10294083525858515 [idw] from 1 files
[DEBUG] running pdal pipeline -i /tmp/tmpzNSGkE.json > /dev/null 2>&1
[INFO] Creating …/var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_dem/dsm_r0.2058816705171703 [idw] from 1 files
[DEBUG] running pdal pipeline -i /tmp/tmpKRHq9V.json > /dev/null 2>&1
[INFO] Creating …/var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_dem/dsm_r0.4117633410343406 [idw] from 1 files
[DEBUG] running pdal pipeline -i /tmp/tmpugtazg.json > /dev/null 2>&1
[INFO] Completed …/var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_dem/dsm_r0.10294083525858515 [idw] in 0:16:50.104079
[INFO] Completed …/var/www/data/08ee2359-2e1d-446c-85c1-fb8d40f18a11/odm_dem/dsm_r0.4117633410343406 [idw] in 0:06:51.357588
plasm.execute(niter=1)
File “/code/scripts/odm_dem.py”, line 112, in process
max_workers=get_max_concurrency_for_dem(args.max_concurrency,tree.odm_georeferencing_model_laz)
File “/code/opendm/dem/commands.py”, line 38, in create_dems
fouts = list(e.map(create_dem_for_radius, radius))
File “/usr/local/lib/python2.7/dist-packages/loky/process_executor.py”, line 794, in _chain_from_iterable_of_lists
for element in iterable:
File “/usr/local/lib/python2.7/dist-packages/loky/_base.py”, line 589, in result_iterator
yield future.result()
File “/usr/local/lib/python2.7/dist-packages/loky/_base.py”, line 426, in result
return self.__get_result()
File “/usr/local/lib/python2.7/dist-packages/loky/_base.py”, line 381, in __get_result
raise self._exception
Exception
: Child returned 1
This was caused directly by
File “/usr/local/lib/python2.7/dist-packages/loky/process_executor.py”, line 418, in _process_worker
r = call_item()
File “/usr/local/lib/python2.7/dist-packages/loky/process_executor.py”, line 272, in call
return self.fn(*self.args, **self.kwargs)
File “/usr/local/lib/python2.7/dist-packages/loky/process_executor.py”, line 337, in _process_chunk
return [fn(*args) for args in chunk]
File “/code/opendm/dem/commands.py”, line 92, in create_dem
pdal.run_pipeline(json, verbose=verbose)
File “/code/opendm/dem/pdal.py”, line 232, in run_pipeline
out = system.run(’ ‘.join(cmd) + ’ > /dev/null 2>&1’)
File “/code/opendm/system.py”, line 34, in run
Exception: Child returned 1
You are probably running out of memory. What happens if you lower --max-concurrency?
