Issue with snap
so i ran the command sudo snap install opendronemap --edge as shown on the snap store on two different systems and i got this error. i later removed the snap and reinstalled it but it wont run or launch
please help
ERROR: ld.so: object ‘/snap/opendronemap/30/lib/libsnapcraft-preload.so’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
File “/snap/opendronemap/30/odm/run.py”, line 10, in
from opendm import config
File “/snap/opendronemap/30/odm/opendm/config.py”, line 6, in
from appsettings import SettingsParser
ModuleNotFoundError: No module named ‘appsettings’
there is a missing module named appsettings in config.py. i just checked it. i may be wrong
Do you think it is this?
That being said, the SNAP should still work, as I get that error when I invoke it directly via the Terminal, but I’m able to process just fine on my Linux laptop.
I’m not entirely sure. it probably is just that but i dont know what exactly should go into the file. i think its best to open an issue on the repository since odm is not working according to the instructions provided on the readme.md file.
A person seeing this for the first time may entirely dismiss odm since the snap doesn’t work which could be undesirable.
@diddledan took care of it for us!
What a mensch!
you’re full of energy, what a community this is.
also will all changes made to the github repository automatically reflect on the snap?
Yes! Dan setup a github action to publish changes immediately to the edge channel of the snap for easy testing.
The WSL and docker images are updated automatically when a new release is tagged. So, we can expect them to be more like “final release” instead of rolling release.
awesome
can you give me any instructions on how to run odm from snap? what are the steps to follow
