I am having some problems trying to reconstruct my orthomosaic when I use the GCPs. I did the gcp_list.txt using the POST GCPi and now the orthomosaic is not reconstructing.
There is this warning:
/usr/local/lib/python3.9/dist-packages/rasterio/io.py:134: NotGeoreferencedWarning: Dataset has no geotransform, gcps, or rpcs. The identity matrix be returned.
What can I do?
Checking the gcp_list the UTM projection is correct.
