Is there a way to copy the options from one task to another?
In WebODM, is there a way to copy al the options from one task to another? I have a lot of custom settings and camera calibration that worked well on a task but I cannot find a way to use all those same options on a new dataset without having to manually set them all again.
Welcome! In WebODM desktop you can save your processing parameters to presets.
In the Lightning web dashboard, you can not currently do so.
Awesome! Thanks!
