Is the model merging run on the mainframe in ClusterODM?
If you’re using WebODM to pass a task to your ClusterODM set up, then the merging of submodels will happen on the processing node that you selected for the task. If you are using the default WebODM processing node then that is where the merge will occur, but you can specify any node you would like this to take place on, and it should be your strongest node.
