I am very new to ODM so please excuse me if I am understanding some things incorrectly. I am working on a project which needs multispectral photos above the forest canopy, so I built one based on raspberry pi. The issue is DJI drone I am using is really not that friendly with integration so I am not really able to give assign metadata to the pictures. I am curious if I can use an already geo referenced map and create the multispectral one using ODM?
This sounds fiddly, but doable. There are a number of different potential approaches, too.
Are the cameras co-located on the drone? Were they flown at the same time?
If so, you can craft a geo.txt using the image center locations of the DJI Visible imagery to locate the Pi-based imagery. https://docs.opendronemap.org/geo/
Yes, hopefully I will mount it on the drone to take the pictures, just that I am not really able to have them do it at the same moment. I was thinking either setting raspberry pi to take pictures more frequently than the drone or gather video and grab frames to lay it on the dji orthophoto. But I am mostly positive they will be taking the pictures in the same mapping operation.
I will further look into the link, thank you for your help!
I looked for a way to do that but this requires for me to write an android app on their new sdk which is still poorly documented sadly. I tried to get over it with using the usb - c port and trigger the camera listening to the directories sadly they put in an restriction for lift off when the port is powered so I am a bit stuck sadly
