I am using WebODM in Japan.
Is it possible to set a link with the original photo when using the downloaded asset on another PC?
I’m not quite sure I understand fully.
Do you have any examples or anything to help illustrate what you need to have happen?
For example, if you upload your own assets with WebODM on a PC installed on another person’s PC, the original photos used to synthesize the orthomosaic image will not be on the other person’s PC.
That’s why it shows “image not found” as in the attached screenshot.
I think that it will be possible to display it if it can be re-associated with the original photo.
We don’t have a way to do this easily currently, no.
Are you in a position to help us implement such a feature?
