Is it possible to model on low-memory server by separating target area into pieces?
When I modelling on low-memory server, it is easy to run out of memory. However, some commercial 3D capture softwares allow separating large area to small pieces. Then align all pieces to a bigger model in order to run that program on low-memory server.
Is it possible with OpenDroneMap?
Hi, this feature exists in ODM (see split/merge). I haven’t used it personally but I know some use it.
Mode indeed exists. Tested and worked on sets of over 2500 images
