I am having an issue with processing large multispectral data sets.
The DJI Phantom 4 Multispectral (5 band) drone will take pictures labeled as “DJI_0011” “DJI_0012” “DJI_0013” “DJI_0014” “DJI_0015”. This is the first image taken by each sensor/band. Then it continues to image two labeled as “DJI_0021” “DJI_0022” “DJI_0023” “DJI_0024” “DJI_0025” and so on for each image. The first 3 numbers are the image count and the last one is the band number. When it runs out of labels it will make a new folder and start over with the same labeling system. When we combine all the images into one folder, Windows prompts “Which image do you want to keep” because there will be images with the same name. We select “keep both” and all of the images in the second folder will have “ (2)” added onto the end, [that is a space then (2)]. So now there will be “DJI_0011” “DJI_0011 (2)” for as many images as are in the second folder from the last part of the flight.
The issue is that WebODM seems to be labeling all the images from the second folder as one band, as a 6th band. So, when I process, it will error saying that the number of images is not correct for a multi-sensor camera.
I was thinking we could change ALL the image names so there are 5 digits instead of 4. So, it could look like DJI_10011 for the first round (folder) of images, DJI_20011 for the second round of images that are labeled with a space and (2). I thought that the program might be using the last digit to separate the bands, so I wanted to keep the last digit consistent with how it was originally labeled.
I came across the same error when all the images had the same format as DJI_10011 for the first folder and DJI_20011 for the second folder.
I made a google docs to share some of the data. There are 30 images that are from folder one and 15 images from folder two. This should show how the duplication happens and how the count would come out as “incorrect”
The full data set has 545 images that have been duplicated from the second folder and last part of the flight. There are 359 images of each band (1-5) from the first folder of images created.
359 * 5 bands = 1795 total images from folder 1 + 545 total images from folder 2 = 2340 total images for the flight
I have included the console.txt file for the first run with the names unchanged, and the second run with the names changed. Any help would be appreciated.
GOOGLE DRIVE FOLDER:
https://drive.google.com/drive/folders/1JGpikDGCsGIyVOfKB6CTXSciXvyauKWI?usp=sharing
[INFO] Initializing ODM 2.8.8 - Tue Aug 09 12:26:18 2022
[INFO] ==============
[INFO] 3d_tiles: False
[INFO] auto_boundary: True
[INFO] auto_boundary_distance: 0
[INFO] boundary: {}
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] cog: True
[INFO] copy_to: None
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: False
[INFO] dtm: False
[INFO] fast_orthophoto: False
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: D:\WebODM\resources\app\apps\NodeODM\data\a7e21e3c-199f-4e34-bda6-f4cadb055689\gcp\NorthHam_multispec_gcp_list.txt
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_neighbors: 0
[INFO] matcher_type: flann
[INFO] max_concurrency: 28
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] name: a7e21e3c-199f-4e34-bda6-f4cadb055689
[INFO] no_gpu: False
[INFO] orthophoto_kmz: False
[INFO] orthophoto_png: False
[INFO] orthophoto_resolution: 3.5
[INFO] pc_classify: False
[INFO] pc_copc: False
[INFO] pc_csv: False
[INFO] pc_ept: True
[INFO] pc_filter: 2.5
[INFO] pc_geometric: False
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] project_path: D:\WebODM\resources\app\apps\NodeODM\data
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] rolling_shutter: False
[INFO] skip_3dmodel: True
[INFO] skip_orthophoto: False
[INFO] skip_report: False
[INFO] sky_removal: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] texturing_skip_global_seam_leveling: True
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: D:\WebODM\resources\app\apps\NodeODM\data\a7e21e3c-199f-4e34-bda6-f4cadb055689\images
[INFO] Loading 2340 images
[INFO] Found 2340 usable images
[ERROR] Multi-camera setup detected, but band “RGB” (identified from “DJI_0011_2.TIF”) has only 545 images (instead of 359), perhaps images are missing or are corrupted. Please include all necessary files to process all bands and try again.
File “D:\WebODM\resources\app\apps\ODM\run.py”, line 59, in
retcode = app.execute()
File “D:\WebODM\resources\app\apps\ODM\stages\odm_app.py”, line 124, in execute
raise e
File “D:\WebODM\resources\app\apps\ODM\stages\odm_app.py”, line 88, in execute
File “D:\WebODM\resources\app\apps\ODM\opendm\types.py”, line 352, in run
File “D:\WebODM\resources\app\apps\ODM\stages\dataset.py”, line 206, in process
reconstruction = types.ODM_Reconstruction(photos)
File “D:\WebODM\resources\app\apps\ODM\opendm\types.py”, line 28, in init
self.multi_camera = self.detect_multi_camera()
File “D:\WebODM\resources\app\apps\ODM\opendm\types.py”, line 55, in detect_multi_camera
raise RuntimeError(“Invalid multi-camera images”)
RuntimeError: Invalid multi-camera images
