Integrate shapefile/dwg to video capture - off-topic?
Hello, I think this is a little bit off-topic for the group but maybe you guys can point me in the right direction.
I am using my drone to make 3d models/videos/orthofotos of sites were plans are made to construct roads. The length of the planned areas varies from 2 km to 10 km. So a boring dronejob - just a straight line :slight_smile:
I would like a way to integrate a shapefile of the planned road (point/polygon/polyline/dwg/dxf/…) to the video. So in my recorded dronevideo, from the preconstruction site I will be able to integrate the plans accurate.
Is there a way/software that can make this happen?
What you are looking for is called motion tracking. You can use software like Adobe After Effects. However, it’s not very straightforward as just loading the shapefile into the software.
There is a solution from a swedish company (you are swedish too right?) called “Hägring Panoptikon” who claims to do this automaticly. I have not tried it myself, but it might be something for you to look into.
