Welcome! That’s an awesome length of time to have been working with photogrammetry. I’ve done manual photogrammetry a few times in my remote sensing class and it broke my brain, so kudos to you haha.
This may seem unhelpful at first, but what you’re experiencing is one of the main drivers behind my funding campaign listed here:
The long and short of it being your likelihood of success under anything more than 16.04LTS goes downhill quite sharply as bare-metal install.
Thanks Saijin, I can understand your response, though I’m a little ‘hesitant’ to enter the world of ‘Snap Packages’ (at this stage…) and I’m not really in a position to assist with ‘funding’, so will take a look at other options, in the meantime.
Tom
I tried to figure out how to update packages and dependencies to get everything working nicely under Ubuntu 20.04LTS, but it was far too big a task for me and I gave up: https://github.com/Saijin-Naib/ODM_Scripts
Now that Piero and Steven have merged a major update and completed ODM 2.0 (ODM 2.0 released! See what's new) you might have better luck getting that running under 20.04LTS.
I think the docker images might be your best/easiest bet at the moment, under 20.04LTS.
Tom, you’ve won my “THANKYOUTHANKYOUTHANKYOU ♂” award for today.
That took us from 3% funded to 5% funded, just with your help alone.
Have you looked into the docker images? I’ve only played with them a little bit, but they’re also just updating to the newer ODM 2.0 release as of just a bit earlier today, so if you checked them out yesterday, today’s another day to do it again
Sorry went ‘off-Topic’, but after discussing with Saijin, tried fresh attempts on Mint20 (lmde) and Manjaro20 using their package-managers to install Docker and Docker-compose…no luck I’m afraid;
This is Mint20 result, hope it helps. Will have a try with the basic Linuxmint20 installation next.
[email protected]:~/WebODM$ ./webodm.sh start
Checking for docker… OK
Checking for git… OK
Starting WebODM…
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
ERROR: for db (‘Connection aborted.’, PermissionError(13, ‘Permission denied’))
ERROR: for node-odm (‘Connection aborted.’, PermissionError(13, ‘Permission denied’))
ERROR: for broker (‘Connection aborted.’, PermissionError(13, ‘Permission denied’))
ERROR: Couldn’t connect to Docker daemon at http+docker://localhost - is it running?
If it’s at a non-standard location, specify the URL with the DOCKER_HOST environment variable.
Tried similar with standard Linuxmint 20 (ubuntu20-based distro), curl script failed so installed docker.io, and docker-compose using package-manager, then ran WebODM script
This is result:
sudo -E sh -c apt-get update -qq >/dev/null
E: The repository ‘https://download.docker.com/linux/debian bullseye Release’ does not have a Release file. [email protected]:~$ docker-compose --version
docker-compose version 1.25.0, build unknown [email protected]:~$ git clone https://github.com/OpenDroneMap/WebODM
Cloning into ‘WebODM’…
remote: Enumerating objects: 14, done.
remote: Counting objects: 100% (14/14), done.
remote: Compressing objects: 100% (9/9), done.
remote: Total 12067 (delta 5), reused 12 (delta 5), pack-reused 12053
Receiving objects: 100% (12067/12067), 103.25 MiB | 2.92 MiB/s, done.
Resolving deltas: 100% (7808/7808), done. [email protected]:~$ cd WebODM [email protected]:~/WebODM$ ./webodm.sh start
Starting WebODM…
Host: localhost
Port: 8000
SSL: NO
SSL key:
SSL certificate:
Default Nodes: 1
