Installing older versions of WebODM
Hi folks,
Just wondering if there there is a way I can install an older version of Webodm? I am able to install using these instruction but it always install the latest version.
Is there a way instead I can install for example version Release 1.4.2 · OpenDroneMap/WebODM · GitHub ?
What platform and method of install?
We don’t officially support older versions; you would need to rebuild the docker images and edit the various docker-compose files to point to your newly rebuilt images.
Are you building a custom version of WebODM? Any reason you can’t use the latest version?
