When I execute “$./webodm. sh rebuild”, Git Bash reports some errors.which point to an address“ https://github.com/OpenDroneMap/WebODM/releases/download/v1.9.2/postgresql- $PG_ VERSION. tar. gz ", it may not be found.
Sorry for the trouble.
That bit of documentation needs to be reworked.
Try following the instructions here:
Thank you for your answer. I reinstalled Docker and then downloaded the image again. It now works normally. I guess some data is not downloaded normally due to unstable network.
Absolutely could be the case! That first pull can be around 4GB and we’ve seen some connections struggle with that.
Glad you’re up and running!
