Initialization failed
Hyper-V Requirements: VM Monitor Mode Extensions: Yes
Initializing console…
OpenSSH check passed
Error checking TLS connection: Host is not running
webodm - virtualbox Stopped Unknown
WebODM VM exists, attempting to launch it…
Starting “webodm”…
(webodm) Check network to re-create if needed…
(webodm) Windows might ask for the permission to create a network adapter. Sometimes, such confirmation window is minimized in the taskbar.
(webodm) Creating a new host-only adapter produced an error: C:\Program Files\Oracle\VirtualBox\VBoxManage.exe hostonlyif create failed:
(webodm) 0%…
(webodm) Progress state: E_FAIL
(webodm) VBoxManage.exe: error: Failed to create the host-only adapter
(webodm) VBoxManage.exe: error: Querying NetCfgInstanceId failed (0x00000002)
(webodm) VBoxManage.exe: error: Details: code E_FAIL (0x80004005), component HostNetworkInterfaceWrap, interface IHostNetworkInterface
(webodm) VBoxManage.exe: error: Context: “enum RTEXITCODE __cdecl handleCreate(struct HandlerArg *)” at line 94 of file VBoxManageHostonly.cpp
(webodm)
(webodm) This is a known VirtualBox bug. Let’s try to recover anyway…
Error setting up host only network on machine start: The host-only adapter we just created is not visible. This is a well known VirtualBox bug. You might want to uninstall it and reinstall at least version 5.0.12 that is is supposed to fix this issue
Could not start virtual machine. Check the console for error messages and attempt to fix the problems manually, then restart this application.
Error checking TLS connection: Machine does not have a host-only adapter
webodm * virtualbox Running Unknown Machine does not have a host-only adapter
