The default is 640 but increasing it to 1000 gives much less points.
47 to 6 million!
47 to 6 million!
It’s a little confusing, because the default isn’t 640. As that’s a deprecated flag that is set by other flags indirectly, I think its default is actually 2400.
Yes, that’s very confusing.
Thanks for the explanation!
The default is a multiple of the image resolution (1/4).
Oh yeah! That.
So maybe setting a multiple instead would be more logical?
The convention matches with other similar software in that we have quality level (low, medium, high, ultra) corresponding to different ratios:
So setting depthmap value is not something to keep doing?
Correct: It is not recommended and might go away as an option eventually.
