Hello folks,
I am having a hard time trying to process this dataset:
https://drive.google.com/drive/folders/1qY2_ZgK1658-XTbgkZ4Cg1bOINyssTHT?usp=sharing
525 photos
Sony Qx1 5456x3632 25mm lens
100m flight height
Corridor mapping with 4 lines
Photos taken every 25m
PPK geotag
This is my last attempt
https://wln2.sfo3.cdn.digitaloceanspaces.com/8f983380-d124-4195-a9dd-0c9858a7a862/all.zip
Options: auto-boundary: true, crop: 0, debug: true, dem-gapfill-steps: 4, dem-resolution: 8, dsm: true, dtm: true, matcher-neighbors: 0, mesh-size: 300000, min-num-features: 20000, orthophoto-resolution: 1
(PiarroPadroPersonalizado-report.pdf)
PiarroPadroPersonalizado-report.pdf (4.0 MB)
So, my ortho is incomplete, missing several photos and I am trying to improve the results.
What I have noted so far:
- the ortho reconstruction stops around an hard area with dense vegetation. Makes sense, dificult to find good features…
- the GPS errors (8.71) are too high and makes no sense to be, because this was recorded using PPK
- changing --gps-accuracy from default 10 to a lower value (like 0.25) didn’t changed the results
- on previous works, the auto camera parameters gave me “v2 sony ilce-qx1 5456 3632 brown 0.0”, however now I am getting “v2 sony ilce-qx1 5456 3632 brown 0.85” with this dataset.
Could some one please take a look at my data set and give a few hints and advice please?
Is my dataset of bad quality? Is the sobreposition too low?
What is the diferrence of “brown 0.0” and “brown 0.85”?
