I was using Propeller to get very high quality orthomosaic maps before with very high detail. I use the orthmosaics to identify vegetation communities in wetlands so the detail is very important to me. It seemed like the orthomosaics that I am getting out of ODM are about a 2.5 in/pixel detail. Are there settings to improve the output when processing the maps? The drone was flown at 225 ft with Drone Deploy mapping.
What sensor are you using? What settings are you using to process?
Just decrease --orthophoto-resolution
and optionally set --ignore-gsd
