The 2 images above are of the same area of a road but both are representative of the entire job. The weird looking one of the two is from WebODM the other is from MapsMadeEasy. I have tried several iterations of the settings and cannot get a usable file. However, the pointcloud is usable. Does anyone have a magic set of settings for roads that will make a better quality image? I also made a 12 point GCP file that did not seem to make a difference.
UPDATE: I made some changes and tried to run a smaller sample of 400 images. It did not make the orthophoto any better and the pointcloud was very sparse.
I will try pierotofy’s suggestion of --use-3dmesh. I may have to switch to the command line. I am using the WebODM now. Also - I wouldn’t mind having only the pointcloud if that is all that will work.
