Import GCP file
Hi everyone,
I’m trying to generate a georeference orthophoto but I don’t know how to import the file gcp. I could use any help.
NRK
Hi NRK,
Have you followed this https://docs.opendronemap.org/gcp.html … if so, just make sure the GCP file is in the same folder as your images, and WebODM will find it. My understanding is that all outputs are in WGS84 UTM30N though at the moment, regardless of the GCP coordinate system.
Hope it helps.
All outputs will be in whatever the closest UTM zone is for your data at the moment. So if I run data from Ohio, it will be UTM 17N; if it’s Zanzibar, it will be UTM 37S, etc…
Thank you very much! My mistake was that I had the wrong filename.
