I started having issues
I updated webodm the other day.
API Version 2.1.4 Engine odm Engine Version 2.4.11 WebODM 1.8.3
Since then I have not been able to process any datasets even old ones that gave great clean results.
I keep getting this error thrown
[INFO] running /code/SuperBuild/install/bin/OpenMVS/ReconstructMesh --mesh-file "/var/www/data/92256672-c4d6-4db7-a09e-a0d81f53625f/odm_meshing/odm_mesh.dirty.ply" -o "/var/www/data/92256672-c4d6-4db7-a09e-a0d81f53625f/odm_meshing/odm_mesh.ply" --remove-spikes 0 --remove-spurious 0 --smooth 0 --target-face-num 1000000 -verbose 17:49:15 [App ] exception thrown: bad lexical cast: source type value could not be interpreted as target
I can provide console.txt if it would help tried to attach but it will not allow a txt file.
Options: camera-lens: brown, debug: true, dem-resolution: 2, dsm: true, dtm: true, feature-quality: ultra, gps-accuracy: 3, mesh-octree-depth: 12, mesh-size: 500000, optimize-disk-space: true, orthophoto-resolution: 1, pc-quality: ultra, texturing-skip-local-seam-leveling: true, use-3dmesh: true, verbose: true
Try running without the --optimize-disk-space parameter.
ok will give it a try real quick.
Saijin same error without --optimize-disk-space
and this is a very small dataset that I have run many times before.
Here is the log files from the console for 2 different data sets.
https://drive.google.com/file/d/1XAm2igr82zmWgZbLPXqOZm7e9hlJWOfN/view?usp=sharing
https://drive.google.com/file/d/12nCrVbaljiM_9T3-aAtHFuIbgkqFqTJD/view?usp=sharing
It looks like a bug introduced in the latest version.
Can you share the images of the smallest dataset you have available that exhibits this problem? (Upload it on https://dronedb.app or google drive)
hey pierotofy, If you can msg me a email or something I could send a you a link.
Sure, just PM me via the forum.
I tried to send you a msg via forum here but it tells me you are not accepting any .
Ah, my bad :slight_smile:
You can use this link then: Contact - UAV4GEO then.
No problem, I sent you a msg.
And the fix: Fix bad lexical cast: source type value could not be interpreted as target by pierotofy · Pull Request #1278 · OpenDroneMap/ODM · GitHub
It’s triggered by the -verbose flag.
Thanks pierotofy looks like you might have rolled back nodeodm?
opendronemap/nodeodm 2.4.10
either way I was able to complete the project I was working on.
3d-model
Nice model! The new version should be up shortly, but yes yesterday I pinned the 2.4.10 version until we fixed the issue on 2.4.12.
Did you manually clean the point cloud? This is so astoundingly clean!
nope, just ran it “64 images” and what you see is what i got. That view is just the model without the point cloud but the point cloud looks pretty darn clean also. I just have to figure out now how to get under the eaves just as clean and fill a few little holes in the model.
