I got error - Process exited with code 1
I just bought and tried my first project. I uploaded the images and when processing, I got the following error code. Please help.
Attached is the URL for google drive:
https://drive.google.com/drive/folders/1H_NcYS8CLtoPgJmFAgJDfu01nBaea4DI?usp=sharing
Created on: 19/06/2020, 18:25:25
Options: mesh-octree-depth: 11, use-3dmesh: true, depthmap-resolution: 1000, mesh-size: 300000
“Process exited with code 1” means that part of the processing failed. Sometimes it’s a problem with the dataset, sometimes it can be solved by tweaking the Task Optionsand sometimes it might be a bug!
Could you attach a copy of the task output? Also, can’t access the shared folder? :pray:
Here again the shared link:
How do I get the task report?
Expand the task from the Dashboard, then press the “Task Output” button and export it.
[INFO] Initializing ODM - Fri Jun 19 10:43:23 2020
[INFO] ==============
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] depthmap_resolution: 1000.0
[INFO] dsm: False
[INFO] dtm: False
[INFO] end_with: odm_report
[INFO] fast_orthophoto: False
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] gps_accuracy: 15
[INFO] ignore_gsd: False
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] max_concurrency: 4
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_point_weight: 4
[INFO] mesh_samples: 1.0
[INFO] mesh_size: 300000
[INFO] min_num_features: 8000
[INFO] mve_confidence: 0.6
[INFO] name: 112cf40d-1f3e-4cfd-a13e-ff4809e517bb
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_multitracks: False
[INFO] split_overlap: 150
[INFO] time: False
[INFO] use_3dmesh: True
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/112cf40d-1f3e-4cfd-a13e-ff4809e517bb/images
[INFO] Loading 189 images
[INFO] Found 189 usable images
[INFO] Parsing SRS header: WGS84 UTM 47N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] [‘use_exif_size: no’, ‘feature_process_size: 2048’, ‘feature_min_frames: 8000’, ‘processes: 4’, ‘matching_gps_neighbors: 8’, ‘matching_gps_distance: 0’, ‘depthmap_method: PATCH_MATCH’, ‘depthmap_resolution: 1000.0’, ‘depthmap_min_patch_sd: 1’, ‘depthmap_min_consistent_views: 3’, ‘optimize_camera_parameters: yes’, ‘undistorted_image_format: tif’, ‘bundle_outlier_filtering_type: AUTO’, ‘align_orientation_prior: vertical’, ‘triangulation_type: ROBUST’, ‘bundle_common_position_constraints: no’, ‘feature_type: SIFT’, ‘use_altitude_tag: yes’, ‘align_method: auto’, ‘local_bundle_radius: 0’]
[INFO] running /usr/bin/env python2 /code/SuperBuild/src/opensfm/bin/opensfm extract_metadata “/var/www/data/112cf40d-1f3e-4cfd-a13e-ff4809e517bb/opensfm”
2020-06-19 10:43:33,767 INFO: Extracting EXIF for DJI_0555.JPG
2020-06-19 10:43:33,823 INFO: Extracting EXIF for DJI_0405.JPG
2020-06-19 10:43:33,857 INFO: Extracting EXIF for DJI_0419.JPG
2020-06-19 10:43:33,892 INFO: Extracting EXIF for DJI_0438.JPG
2020-06-19 10:43:33,921 INFO: Extracting EXIF for DJI_0429.JPG
2020-06-19 10:43:33,951 INFO: Extracting EXIF for DJI_0411.JPG
2020-06-19 10:43:33,979 INFO: Extracting EXIF for DJI_0435.JPG
2020-06-19 10:43:34,010 INFO: Extracting EXIF for DJI_0551.JPG
2020-06-19 10:43:34,043 INFO: Extracting EXIF for DJI_0486.JPG
2020-06-19 10:43:34,079 INFO: Extracting EXIF for DJI_0478.JPG
2020-06-19 10:43:34,110 INFO: Extracting EXIF for DJI_0408.JPG
2020-06-19 10:43:34,139 INFO: Extracting EXIF for DJI_0443.JPG
2020-06-19 10:43:34,168 INFO: Extracting EXIF for DJI_0434.JPG
2020-06-19 10:43:34,194 INFO: Extracting EXIF for DJI_0571.JPG
2020-06-19 10:43:34,231 INFO: Extracting EXIF for DJI_0522.JPG
2020-06-19 10:43:34,268 INFO: Extracting EXIF for DJI_0461.JPG
2020-06-19 10:43:34,302 INFO: Extracting EXIF for DJI_0514.JPG
2020-06-19 10:43:34,346 INFO: Extracting EXIF for DJI_0444.JPG
2020-06-19 10:43:34,378 INFO: Extracting EXIF for DJI_0453.JPG
2020-06-19 10:43:34,410 INFO: Extracting EXIF for DJI_0564.JPG
2020-06-19 10:43:34,444 INFO: Extracting EXIF for DJI_0504.JPG
2020-06-19 10:43:34,482 INFO: Extracting EXIF for DJI_0440.JPG
2020-06-19 10:43:34,510 INFO: Extracting EXIF for DJI_0442.JPG
2020-06-19 10:43:34,541 INFO: Extracting EXIF for DJI_0575.JPG
2020-06-19 10:43:34,574 INFO: Extracting EXIF for DJI_0515.JPG
2020-06-19 10:43:34,615 INFO: Extracting EXIF for DJI_0439.JPG
2020-06-19 10:43:34,647 INFO: Extracting EXIF for DJI_0456.JPG
2020-06-19 10:43:34,676 INFO: Extracting EXIF for DJI_0505.JPG
2020-06-19 10:43:34,714 INFO: Extracting EXIF for DJI_0563.JPG
2020-06-19 10:43:34,742 INFO: Extracting EXIF for DJI_0506.JPG
2020-06-19 10:43:34,776 INFO: Extracting EXIF for DJI_0417.JPG
2020-06-19 10:43:34,804 INFO: Extracting EXIF for DJI_0528.JPG
2020-06-19 10:43:34,844 INFO: Extracting EXIF for DJI_0414.JPG
2020-06-19 10:43:34,877 INFO: Extracting EXIF for DJI_0524.JPG
2020-06-19 10:43:34,916 INFO: Extracting EXIF for DJI_0404.JPG
2020-06-19 10:43:34,948 INFO: Extracting EXIF for DJI_0539.JPG
2020-06-19 10:43:34,978 INFO: Extracting EXIF for DJI_0403.JPG
2020-06-19 10:43:35,010 INFO: Extracting EXIF for DJI_0437.JPG
2020-06-19 10:43:35,043 INFO: Extracting EXIF for DJI_0516.JPG
2020-06-19 10:43:35,077 INFO: Extracting EXIF for DJI_0572.JPG
2020-06-19 10:43:35,104 INFO: Extracting EXIF for DJI_0487.JPG
2020-06-19 10:43:35,142 INFO: Extracting EXIF for DJI_0574.JPG
2020-06-19 10:43:35,175 INFO: Extracting EXIF for DJI_0424.JPG
2020-06-19 10:43:35,209 INFO: Extracting EXIF for DJI_0507.JPG
2020-06-19 10:43:35,242 INFO: Extracting EXIF for DJI_0407.JPG
2020-06-19 10:43:35,270 INFO: Extracting EXIF for DJI_0562.JPG
2020-06-19 10:43:35,300 INFO: Extracting EXIF for DJI_0477.JPG
2020-06-19 10:43:35,334 INFO: Extracting EXIF for DJI_0553.JPG
2020-06-19 10:43:35,362 INFO: Extracting EXIF for DJI_0549.JPG
2020-06-19 10:43:35,396 INFO: Extracting EXIF for DJI_0465.JPG
2020-06-19 10:43:35,426 INFO: Extracting EXIF for DJI_0587.JPG
2020-06-19 10:43:35,457 INFO: Extracting EXIF for DJI_0550.JPG
2020-06-19 10:43:35,483 INFO: Extracting EXIF for DJI_0441.JPG
2020-06-19 10:43:35,512 INFO: Extracting EXIF for DJI_0402.JPG
2020-06-19 10:43:35,544 INFO: Extracting EXIF for DJI_0494.JPG
2020-06-19 10:43:35,586 INFO: Extracting EXIF for DJI_0485.JPG
2020-06-19 10:43:35,628 INFO: Extracting EXIF for DJI_0468.JPG
2020-06-19 10:43:35,656 INFO: Extracting EXIF for DJI_0448.JPG
2020-06-19 10:43:35,686 INFO: Extracting EXIF for DJI_0503.JPG
2020-06-19 10:43:35,726 INFO: Extracting EXIF for DJI_0472.JPG
2020-06-19 10:43:35,755 INFO: Extracting EXIF for DJI_0583.JPG
2020-06-19 10:43:35,779 INFO: Extracting EXIF for DJI_0513.JPG
2020-06-19 10:43:35,819 INFO: Extracting EXIF for DJI_0473.JPG
2020-06-19 10:43:35,849 INFO: Extracting EXIF for DJI_0493.JPG
2020-06-19 10:43:35,889 INFO: Extracting EXIF for DJI_0547.JPG
2020-06-19 10:43:35,918 INFO: Extracting EXIF for DJI_0584.JPG
2020-06-19 10:43:35,946 INFO: Extracting EXIF for DJI_0457.JPG
2020-06-19 10:43:35,976 INFO: Extracting EXIF for DJI_0529.JPG
2020-06-19 10:43:36,014 INFO: Extracting EXIF for DJI_0423.JPG
2020-06-19 10:43:36,043 INFO: Extracting EXIF for DJI_0554.JPG
2020-06-19 10:43:36,075 INFO: Extracting EXIF for DJI_0476.JPG
2020-06-19 10:43:36,122 INFO: Extracting EXIF for DJI_0480.JPG
2020-06-19 10:43:36,164 INFO: Extracting EXIF for DJI_0582.JPG
2020-06-19 10:43:36,197 INFO: Extracting EXIF for DJI_0525.JPG
2020-06-19 10:43:36,234 INFO: Extracting EXIF for DJI_0542.JPG
2020-06-19 10:43:36,264 INFO: Extracting EXIF for DJI_0455.JPG
2020-06-19 10:43:36,297 INFO: Extracting EXIF for DJI_0459.JPG
2020-06-19 10:43:36,331 INFO: Extracting EXIF for DJI_0586.JPG
2020-06-19 10:43:36,361 INFO: Extracting EXIF for DJI_0527.JPG
2020-06-19 10:43:36,398 INFO: Extracting EXIF for DJI_0464.JPG
2020-06-19 10:43:36,427 INFO: Extracting EXIF for DJI_0400.JPG
2020-06-19 10:43:36,451 INFO: Extracting EXIF for DJI_0463.JPG
2020-06-19 10:43:36,480 INFO: Extracting EXIF for DJI_0454.JPG
2020-06-19 10:43:36,511 INFO: Extracting EXIF for DJI_0426.JPG
2020-06-19 10:43:36,543 INFO: Extracting EXIF for DJI_0492.JPG
2020-06-19 10:43:36,589 INFO: Extracting EXIF for DJI_0517.JPG
2020-06-19 10:43:36,624 INFO: Extracting EXIF for DJI_0552.JPG
2020-06-19 10:43:36,658 INFO: Extracting EXIF for DJI_0406.JPG
2020-06-19 10:43:36,686 INFO: Extracting EXIF for DJI_0580.JPG
2020-06-19 10:43:36,719 INFO: Extracting EXIF for DJI_0559.JPG
2020-06-19 10:43:36,750 INFO: Extracting EXIF for DJI_0560.JPG
2020-06-19 10:43:36,782 INFO: Extracting EXIF for DJI_0534.JPG
2020-06-19 10:43:36,814 INFO: Extracting EXIF for DJI_0501.JPG
2020-06-19 10:43:36,867 INFO: Extracting EXIF for DJI_0490.JPG
2020-06-19 10:43:36,920 INFO: Extracting EXIF for DJI_0425.JPG
2020-06-19 10:43:36,955 INFO: Extracting EXIF for DJI_0544.JPG
2020-06-19 10:43:36,984 INFO: Extracting EXIF for DJI_0418.JPG
2020-06-19 10:43:37,016 INFO: Extracting EXIF for DJI_0484.JPG
2020-06-19 10:43:37,058 INFO: Extracting EXIF for DJI_0585.JPG
2020-06-19 10:43:37,087 INFO: Extracting EXIF for DJI_0497.JPG
2020-06-19 10:43:37,141 INFO: Extracting EXIF for DJI_0577.JPG
2020-06-19 10:43:37,176 INFO: Extracting EXIF for DJI_0556.JPG
2020-06-19 10:43:37,208 INFO: Extracting EXIF for DJI_0498.JPG
2020-06-19 10:43:37,247 INFO: Extracting EXIF for DJI_0481.JPG
2020-06-19 10:43:37,304 INFO: Extracting EXIF for DJI_0422.JPG
2020-06-19 10:43:37,333 INFO: Extracting EXIF for DJI_0479.JPG
2020-06-19 10:43:37,375 INFO: Extracting EXIF for DJI_0447.JPG
2020-06-19 10:43:37,406 INFO: Extracting EXIF for DJI_0533.JPG
2020-06-19 10:43:37,432 INFO: Extracting EXIF for DJI_0558.JPG
2020-06-19 10:43:37,463 INFO: Extracting EXIF for DJI_0521.JPG
2020-06-19 10:43:37,497 INFO: Extracting EXIF for DJI_0471.JPG
2020-06-19 10:43:37,552 INFO: Extracting EXIF for DJI_0588.JPG
2020-06-19 10:43:37,588 INFO: Extracting EXIF for DJI_0523.JPG
2020-06-19 10:43:37,634 INFO: Extracting EXIF for DJI_0449.JPG
2020-06-19 10:43:37,665 INFO: Extracting EXIF for DJI_0458.JPG
2020-06-19 10:43:37,726 INFO: Extracting EXIF for DJI_0495.JPG
2020-06-19 10:43:37,780 INFO: Extracting EXIF for DJI_0532.JPG
2020-06-19 10:43:37,813 INFO: Extracting EXIF for DJI_0518.JPG
2020-06-19 10:43:37,850 INFO: Extracting EXIF for DJI_0526.JPG
2020-06-19 10:43:37,879 INFO: Extracting EXIF for DJI_0416.JPG
2020-06-19 10:43:37,913 INFO: Extracting EXIF for DJI_0546.JPG
2020-06-19 10:43:37,942 INFO: Extracting EXIF for DJI_0499.JPG
2020-06-19 10:43:37,984 INFO: Extracting EXIF for DJI_0512.JPG
2020-06-19 10:43:38,019 INFO: Extracting EXIF for DJI_0413.JPG
2020-06-19 10:43:38,050 INFO: Extracting EXIF for DJI_0500.JPG
2020-06-19 10:43:38,093 INFO: Extracting EXIF for DJI_0538.JPG
2020-06-19 10:43:38,124 INFO: Extracting EXIF for DJI_0401.JPG
2020-06-19 10:43:38,154 INFO: Extracting EXIF for DJI_0452.JPG
2020-06-19 10:43:38,186 INFO: Extracting EXIF for DJI_0436.JPG
2020-06-19 10:43:38,214 INFO: Extracting EXIF for DJI_0568.JPG
2020-06-19 10:43:38,244 INFO: Extracting EXIF for DJI_0511.JPG
2020-06-19 10:43:38,288 INFO: Extracting EXIF for DJI_0409.JPG
2020-06-19 10:43:38,323 INFO: Extracting EXIF for DJI_0579.JPG
2020-06-19 10:43:38,354 INFO: Extracting EXIF for DJI_0466.JPG
2020-06-19 10:43:38,413 INFO: Extracting EXIF for DJI_0567.JPG
2020-06-19 10:43:38,459 INFO: Extracting EXIF for DJI_0412.JPG
2020-06-19 10:43:38,491 INFO: Extracting EXIF for DJI_0451.JPG
2020-06-19 10:43:38,525 INFO: Extracting EXIF for DJI_0483.JPG
2020-06-19 10:43:38,610 INFO: Extracting EXIF for DJI_0431.JPG
2020-06-19 10:43:38,659 INFO: Extracting EXIF for DJI_0420.JPG
2020-06-19 10:43:38,694 INFO: Extracting EXIF for DJI_0548.JPG
2020-06-19 10:43:38,724 INFO: Extracting EXIF for DJI_0428.JPG
2020-06-19 10:43:38,764 INFO: Extracting EXIF for DJI_0410.JPG
2020-06-19 10:43:38,805 INFO: Extracting EXIF for DJI_0450.JPG
2020-06-19 10:43:38,838 INFO: Extracting EXIF for DJI_0581.JPG
2020-06-19 10:43:38,869 INFO: Extracting EXIF for DJI_0570.JPG
2020-06-19 10:43:38,903 INFO: Extracting EXIF for DJI_0446.JPG
2020-06-19 10:43:38,936 INFO: Extracting EXIF for DJI_0491.JPG
2020-06-19 10:43:38,977 INFO: Extracting EXIF for DJI_0561.JPG
2020-06-19 10:43:39,010 INFO: Extracting EXIF for DJI_0460.JPG
2020-06-19 10:43:39,045 INFO: Extracting EXIF for DJI_0545.JPG
2020-06-19 10:43:39,081 INFO: Extracting EXIF for DJI_0475.JPG
2020-06-19 10:43:39,128 INFO: Extracting EXIF for DJI_0543.JPG
2020-06-19 10:43:39,160 INFO: Extracting EXIF for DJI_0566.JPG
2020-06-19 10:43:39,195 INFO: Extracting EXIF for DJI_0421.JPG
2020-06-19 10:43:39,227 INFO: Extracting EXIF for DJI_0565.JPG
2020-06-19 10:43:39,258 INFO: Extracting EXIF for DJI_0531.JPG
2020-06-19 10:43:39,287 INFO: Extracting EXIF for DJI_0415.JPG
2020-06-19 10:43:39,321 INFO: Extracting EXIF for DJI_0520.JPG
2020-06-19 10:43:39,351 INFO: Extracting EXIF for DJI_0535.JPG
2020-06-19 10:43:39,384 INFO: Extracting EXIF for DJI_0541.JPG
2020-06-19 10:43:39,417 INFO: Extracting EXIF for DJI_0508.JPG
2020-06-19 10:43:39,452 INFO: Extracting EXIF for DJI_0519.JPG
2020-06-19 10:43:39,483 INFO: Extracting EXIF for DJI_0467.JPG
2020-06-19 10:43:39,530 INFO: Extracting EXIF for DJI_0576.JPG
2020-06-19 10:43:39,563 INFO: Extracting EXIF for DJI_0482.JPG
2020-06-19 10:43:39,606 INFO: Extracting EXIF for DJI_0496.JPG
2020-06-19 10:43:39,649 INFO: Extracting EXIF for DJI_0489.JPG
2020-06-19 10:43:39,695 INFO: Extracting EXIF for DJI_0462.JPG
2020-06-19 10:43:39,728 INFO: Extracting EXIF for DJI_0578.JPG
2020-06-19 10:43:39,760 INFO: Extracting EXIF for DJI_0569.JPG
2020-06-19 10:43:39,788 INFO: Extracting EXIF for DJI_0573.JPG
2020-06-19 10:43:39,818 INFO: Extracting EXIF for DJI_0509.JPG
2020-06-19 10:43:39,849 INFO: Extracting EXIF for DJI_0540.JPG
2020-06-19 10:43:39,881 INFO: Extracting EXIF for DJI_0430.JPG
2020-06-19 10:43:39,911 INFO: Extracting EXIF for DJI_0488.JPG
2020-06-19 10:43:39,951 INFO: Extracting EXIF for DJI_0427.JPG
2020-06-19 10:43:39,983 INFO: Extracting EXIF for DJI_0470.JPG
2020-06-19 10:43:40,028 INFO: Extracting EXIF for DJI_0433.JPG
2020-06-19 10:43:40,062 INFO: Extracting EXIF for DJI_0536.JPG
2020-06-19 10:43:40,094 INFO: Extracting EXIF for DJI_0530.JPG
2020-06-19 10:43:40,123 INFO: Extracting EXIF for DJI_0445.JPG
2020-06-19 10:43:40,152 INFO: Extracting EXIF for DJI_0432.JPG
2020-06-19 10:43:40,188 INFO: Extracting EXIF for DJI_0469.JPG
2020-06-19 10:43:40,228 INFO: Extracting EXIF for DJI_0502.JPG
2020-06-19 10:43:40,257 INFO: Extracting EXIF for DJI_0537.JPG
2020-06-19 10:43:40,287 INFO: Extracting EXIF for DJI_0510.JPG
2020-06-19 10:43:40,313 INFO: Extracting EXIF for DJI_0474.JPG
2020-06-19 10:43:40,356 INFO: Extracting EXIF for DJI_0557.JPG
[INFO] running /usr/bin/env python2 /code/SuperBuild/src/opensfm/bin/opensfm detect_features “/var/www/data/112cf40d-1f3e-4cfd-a13e-ff4809e517bb/opensfm”
2020-06-19 10:43:45,907 INFO: Extracting ROOT_SIFT features for image DJI_0555.JPG
2020-06-19 10:43:46,286 DEBUG: Computing sift with threshold 0.1
2020-06-19 10:43:49,844 INFO: Extracting ROOT_SIFT features for image DJI_0405.JPG
2020-06-19 10:43:50,379 DEBUG: Computing sift with threshold 0.1
2020-06-19 10:43:53,963 DEBUG: Found 13867 points in 7.67542099953s
2020-06-19 10:43:54,011 DEBUG: done
2020-06-19 10:43:59,998 INFO: Extracting ROOT_SIFT features for image DJI_0419.JPG
2020-06-19 10:44:00,631 DEBUG: Found 6835 points in 10.2486550808s
2020-06-19 10:44:00,632 DEBUG: reducing threshold
2020-06-19 10:44:00,632 DEBUG: Computing sift with threshold 0.0666666666667
2020-06-19 10:44:02,670 DEBUG: Computing sift with threshold 0.1
2020-06-19 10:44:10,985 DEBUG: No segmentation for DJI_0555.JPG, no features masked.
2020-06-19 10:44:20,775 DEBUG: Found 14520 points in 20.1415171623s
2020-06-19 10:44:21,113 DEBUG: done
2020-06-19 10:44:24,296 DEBUG: Found 9388 points in 21.6137831211s
2020-06-19 10:44:24,324 DEBUG: done
2020-06-19 10:44:25,853 INFO: Extracting ROOT_SIFT features for image DJI_0438.JPG
2020-06-19 10:44:25,854 INFO: Extracting ROOT_SIFT features for image DJI_0429.JPG
2020-06-19 10:44:26,775 DEBUG: Computing sift with threshold 0.1
2020-06-19 10:44:27,248 DEBUG: Computing sift with threshold 0.1
2020-06-19 10:44:53,090 ERROR: exception calling callback for <Future at 0x7f8614ad9150 state=finished raised TerminatedWorkerError>
File “/usr/local/lib/python2.7/dist-packages/joblib/externals/loky/_base.py”, line 625, in _invoke_callbacks
callback(self)
File “/usr/local/lib/python2.7/dist-packages/joblib/parallel.py”, line 309, in call
self.parallel.dispatch_next()
File “/usr/local/lib/python2.7/dist-packages/joblib/parallel.py”, line 731, in dispatch_next
if not self.dispatch_one_batch(self._original_iterator):
File “/usr/local/lib/python2.7/dist-packages/joblib/parallel.py”, line 759, in dispatch_one_batch
self._dispatch(tasks)
File “/usr/local/lib/python2.7/dist-packages/joblib/parallel.py”, line 716, in _dispatch
job = self._backend.apply_async(batch, callback=cb)
File “/usr/local/lib/python2.7/dist-packages/joblib/_parallel_backends.py”, line 510, in apply_async
future = self._workers.submit(SafeFunction(func))
File “/usr/local/lib/python2.7/dist-packages/joblib/externals/loky/reusable_executor.py”, line 151, in submit
fn, *args, **kwargs)
File “/usr/local/lib/python2.7/dist-packages/joblib/externals/loky/process_executor.py”, line 1022, in submit
raise self._flags.broken
TerminatedWorkerError: A worker process managed by the executor was unexpectedly terminated. This could be caused by a segmentation fault while calling the function or by an excessive memory usage causing the Operating System to kill the worker. The exit codes of the workers are {SIGKILL(-9)}
File “/code/SuperBuild/src/opensfm/bin/opensfm”, line 34, in
command.run(args)
File “/code/SuperBuild/src/opensfm/opensfm/commands/detect_features.py”, line 31, in run
parallel_map(detect, arguments, processes, 1)
File “/code/SuperBuild/src/opensfm/opensfm/context.py”, line 41, in parallel_map
return Parallel(batch_size=batch_size)(delayed(func)(arg) for arg in args)
File “/usr/local/lib/python2.7/dist-packages/joblib/parallel.py”, line 934, in call
self.retrieve()
File “/usr/local/lib/python2.7/dist-packages/joblib/parallel.py”, line 833, in retrieve
File “/usr/local/lib/python2.7/dist-packages/joblib/_parallel_backends.py”, line 521, in wrap_future_result
return future.result(timeout=timeout)
File “/usr/local/lib/python2.7/dist-packages/joblib/externals/loky/_base.py”, line 433, in result
return self.__get_result()
File “/usr/local/lib/python2.7/dist-packages/joblib/externals/loky/_base.py”, line 381, in __get_result
raise self._exception
joblib.externals.loky.process_executor.TerminatedWorkerError: A worker process managed by the executor was unexpectedly terminated. This could be caused by a segmentation fault while calling the function or by an excessive memory usage causing the Operating System to kill the worker. The exit codes of the workers are {SIGKILL(-9)}
File “/code/run.py”, line 61, in
app.execute()
File “/code/stages/odm_app.py”, line 95, in execute
File “/code/opendm/types.py”, line 350, in run
File “/code/opendm/types.py”, line 331, in run
File “/code/stages/run_opensfm.py”, line 30, in process
File “/code/opendm/osfm.py”, line 234, in feature_matching
self.run(‘detect_features’)
File “/code/opendm/osfm.py”, line 23, in run
Exception: Child returned 1
It seems like you ran out of memory? Check from Diagnostic panel how much memory you’ve allocated. You might need to allocate more memory to the docker program.
Oh dear… how do I check and allocate? I am very new to this…
Haven’t yet been able to get up and running on WebODM myself, but may as well attempt to answer this while I wait for some to answer my own query on processing nodes.
You can check by clicking on the Diagnostic option in the left hand menu of WebODM. The right hand pie chart shows how much memory is allocated.
You can allocate more by going into Oracle VM Virtualbox Manager (assuming this is your VM) and right clicking the VM. Select Close and then ACPI Shutdown. Then you can right click again and select Settings. Click on System (second option down in the left menu) and, on the Motherboard tab, there is a slider to select how much memory to allocate to the VM. Piero Toffanin recommends allocating 60-70% of the total memory available, i.e. for a computer with 16GB you might wish to allocate 10GB.
Then restart the VM and start up WebODM.
Also, try to remove these two images. Perhaps there’s something wrong with them.
