I can´t install ODM in MacOS Sierra
I just got ODM and I don’t have programming skills. I have installed docker and I use ODM (command line). I wanted the webODM interface but I can’t install!
Thanks in advance
Juan Diego
01
Hey @juandiegovele :hand: did you copy the application to your Applications folder? Also do you get any errors when you launch the application?
Hey I did, also I allowed to install the app In the privacy and security settings and I allways get this message.51
Mm, could you copy paste the full output of the window? It might have more information as to the cause of the error. Also, do you have any third party antivirus/security software running?
Yes, I pasted without ploblem the file ODM manager into the app folder as the manual said. I received three files 2 PDF’s; the installation manual and a thanks note plus the ODM manager file. I don’t have another antivirus
Maybe I couldn’t explained well. I have the free (comand line ODM version in my Macbook) It works well but doesn’t make DEM files son I wanted to improve and I purchased ODM desktop version but I can’t install.
What I meant is if you could take the output from the screenshot (the one with the error) and write it on this thread in full so that we can better understand what the problem could be.
p.s. did you pass the --dsm option to command line ODM to get an elevation model?
Ok, I’ll send you later as soon as I get home. On the other topic, I don’t know how to use that command, so far I just use the orthophoto. Could you please explain me how to do that?
this is the message that I got during the installation, Its very long, so I divided in three parts. 1/3
Process: WebODM Manager [628]
Path: /Applications/WebODM Manager.app/Contents/MacOS/WebODM Manager
Identifier: com.masseranolabs.WebODM-Manager
Version: 1.1 (1)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: WebODM Manager [628]
User ID: 501
Date/Time: 2019-06-27 20:35:29.336 -0500
OS Version: Mac OS X 10.12.6 (16G1212)
Report Version: 12
Anonymous UUID: B6635B2E-DB8C-AE99-08C2-AB1499284B7B
Time Awake Since Boot: 420 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
*** Terminating app due to uncaught exception ‘NSInvalidArgumentException’, reason: ‘launch path not accessible’
terminating with uncaught exception of type NSException
abort() called
Application Specific Backtrace 1:
0 CoreFoundation 0x00007fffcf39557b __exceptionPreprocess + 171
1 libobjc.A.dylib 0x00007fffe45f51da objc_exception_throw + 48
2 CoreFoundation 0x00007fffcf412c55 +[NSException raise:format:] + 197
3 Foundation 0x00007fffd0ddca0e -[NSConcreteTask launchWithDictionary:] + 414
4 WebODM Manager 0x000000010b2ea84c WebODM Manager + 63564
5 WebODM Manager 0x000000010b2e0619 WebODM Manager + 22041
6 WebODM Manager 0x000000010b2dfac9 WebODM Manager + 19145
7 WebODM Manager 0x000000010b2dfb27 WebODM Manager + 19239
8 AppKit 0x00007fffccf41264 -[NSViewController _sendViewDidAppear] + 41
9 AppKit 0x00007fffccf40f5b -[NSView(NSInternal) _windowDidOrderOnScreen] + 67
10 AppKit 0x00007fffccf4100e -[NSView(NSInternal) _windowDidOrderOnScreen] + 246
11 AppKit 0x00007fffcd6a5a38 -[NSWindow _reallyDoOrderWindowAboveOrBelow:relativeTo:findKey:forCounter:force:isModal:] + 2532
12 AppKit 0x00007fffccf3d6ce -[NSWindow _doOrderWindow:relativeTo:findKey:forCounter:force:isModal:] + 1041
13 AppKit 0x00007fffccf3d263 -[NSWindow orderWindow:relativeTo:] + 153
14 AppKit 0x00007fffccfefbab -[NSWindow makeKeyAndOrderFront:] + 111
15 QuickLookUI 0x00007fffd5183519 -[QLSeamlessDocumentOpener showWindow:contentFrame:withBlock:] + 108
16 AppKit 0x00007fffccfeed37 -[NSWindowController showWindow:] + 689
17 AppKit 0x00007fffccdc1d2e NSApplicationMain + 1013
18 WebODM Manager 0x000000010b2e37b9 WebODM Manager + 34745
19 libdyld.dylib 0x00007fffe4ed6235 start + 1
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fffe5004d42 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fffe50f2457 pthread_kill + 90
2 libsystem_c.dylib 0x00007fffe4f6a420 abort + 129
3 libc++abi.dylib 0x00007fffe3ac394a abort_message + 266
4 libc++abi.dylib 0x00007fffe3ae8c2f default_terminate_handler() + 267
5 libobjc.A.dylib 0x00007fffe45f733e _objc_terminate() + 103
6 libc++abi.dylib 0x00007fffe3ae5d49 std::__terminate(void (*)()) + 8
7 libc++abi.dylib 0x00007fffe3ae59d2 __cxa_rethrow + 99
8 libobjc.A.dylib 0x00007fffe45f56b7 objc_exception_rethrow + 40
9 com.apple.Foundation 0x00007fffd0ddd7e4 -[NSConcreteTask launchWithDictionary:] + 3956
10 com.masseranolabs.WebODM-Manager 0x000000010b2ea84c 0x10b2db000 + 63564
11 com.masseranolabs.WebODM-Manager 0x000000010b2e0619 0x10b2db000 + 22041
12 com.masseranolabs.WebODM-Manager 0x000000010b2dfac9 0x10b2db000 + 19145
13 com.masseranolabs.WebODM-Manager 0x000000010b2dfb27 0x10b2db000 + 19239
14 com.apple.AppKit 0x00007fffccf41264 -[NSViewController _sendViewDidAppear] + 41
15 com.apple.AppKit 0x00007fffccf40f5b -[NSView(NSInternal) _windowDidOrderOnScreen] + 67
16 com.apple.AppKit 0x00007fffccf4100e -[NSView(NSInternal) _windowDidOrderOnScreen] + 246
17 com.apple.AppKit 0x00007fffcd6a5a38 -[NSWindow _reallyDoOrderWindowAboveOrBelow:relativeTo:findKey:forCounter:force:isModal:] + 2532
18 com.apple.AppKit 0x00007fffccf3d6ce -[NSWindow _doOrderWindow:relativeTo:findKey:forCounter:force:isModal:] + 1041
19 com.apple.AppKit 0x00007fffccf3d263 -[NSWindow orderWindow:relativeTo:] + 153
20 com.apple.AppKit 0x00007fffccfefbab -[NSWindow makeKeyAndOrderFront:] + 111
21 com.apple.QuickLookUIFramework 0x00007fffd5183519 -[QLSeamlessDocumentOpener showWindow:contentFrame:withBlock:] + 108
22 com.apple.AppKit 0x00007fffccfeed37 -[NSWindowController showWindow:] + 689
23 com.apple.AppKit 0x00007fffccdc1d2e NSApplicationMain + 1013
24 com.masseranolabs.WebODM-Manager 0x000000010b2e37b9 0x10b2db000 + 34745
25 libdyld.dylib 0x00007fffe4ed6235 start + 1
Thread 1:
0 libsystem_kernel.dylib 0x00007fffe500544e __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fffe50ef621 _pthread_wqthread + 1426
2 libsystem_pthread.dylib 0x00007fffe50ef07d start_wqthread + 13
Thread 2:
Thread 3:
0 libsystem_pthread.dylib 0x00007fffe50ef070 start_wqthread + 0
1 ??? 0x00007fffedd8c480 headPagePairs + 48
Thread 4:
1 libsystem_pthread.dylib 0x00007fffe50ef48e _pthread_wqthread + 1023
Thread 5:: com.apple.appkit-heartbeat
0 libsystem_kernel.dylib 0x00007fffe5004f46 __semwait_signal + 10
1 libsystem_c.dylib 0x00007fffe4f8bb72 nanosleep + 199
2 libsystem_c.dylib 0x00007fffe4f8ba66 usleep + 54
3 com.apple.AppKit 0x00007fffcd0ccaf6 -[NSUIHeartBeat _heartBeatThread:] + 2696
4 com.apple.Foundation 0x00007fffd0d4d8ad NSThread__start + 1243
5 libsystem_pthread.dylib 0x00007fffe50ef93b _pthread_body + 180
6 libsystem_pthread.dylib 0x00007fffe50ef887 _pthread_start + 286
7 libsystem_pthread.dylib 0x00007fffe50ef08d thread_start + 13
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x00007fff54923a48 rdx: 0x0000000000000000
rdi: 0x0000000000000307 rsi: 0x0000000000000006 rbp: 0x00007fff54923a70 rsp: 0x00007fff54923a48
r8: 0x00007fffe4f93650 r9: 0x00007fffe4f55a50 r10: 0x0000000008000000 r11: 0x0000000000000206
r12: 0x00007fff54923bd0 r13: 0x0000000000000030 r14: 0x00007fffede403c0 r15: 0x0000000000000008
rip: 0x00007fffe5004d42 rfl: 0x0000000000000206 cr2: 0x00007fffede22128
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
2/3
Binary Images:
0x10b2db000 - 0x10b2f3ff7 +com.masseranolabs.WebODM-Manager (1.1 - 1) <7B8FFFBB-707D-339C-B200-8C88EB2808C8> /Applications/WebODM Manager.app/Contents/MacOS/WebODM Manager
0x10b302000 - 0x10b314ff7 +libswiftAppKit.dylib (4.1 - 902.0.48) <6FF8358D-62C2-3B2B-B481-B2D98F0D2DE2> /Applications/WebODM Manager.app/Contents/Frameworks/libswiftAppKit.dylib
0x10b332000 - 0x10b685fff +libswiftCore.dylib (4.1 - 902.0.48) <46A0F815-5A46-3D4C-B60E-E5FCE8A1699A> /Applications/WebODM Manager.app/Contents/Frameworks/libswiftCore.dylib
0x10b935000 - 0x10b93eff7 +libswiftCoreData.dylib (4.1 - 902.0.48) <1190EE0F-A88A-32CC-9C07-37BD547CFEA1> /Applications/WebODM Manager.app/Contents/Frameworks/libswiftCoreData.dylib
0x10b954000 - 0x10b957fff +libswiftCoreFoundation.dylib (4.1 - 902.0.48) /Applications/WebODM Manager.app/Contents/Frameworks/libswiftCoreFoundation.dylib
0x10b95e000 - 0x10b970fff +libswiftCoreGraphics.dylib (4.1 - 902.0.48) /Applications/WebODM Manager.app/Contents/Frameworks/libswiftCoreGraphics.dylib
0x10b98d000 - 0x10b992ffe +libswiftCoreImage.dylib (4.1 - 902.0.48) <86FC0AAA-254A-331A-BCAD-F553512CBDB2> /Applications/WebODM Manager.app/Contents/Frameworks/libswiftCoreImage.dylib
0x10b99a000 - 0x10b9a1fff +libswiftDarwin.dylib (4.1 - 902.0.48) <58E8C76E-2C42-39B8-BA51-43BA61F44134> /Applications/WebODM Manager.app/Contents/Frameworks/libswiftDarwin.dylib
0x10b9b1000 - 0x10b9cbfff +libswiftDispatch.dylib (4.1 - 902.0.48) /Applications/WebODM Manager.app/Contents/Frameworks/libswiftDispatch.dylib
0x10b9fd000 - 0x10bb70fff +libswiftFoundation.dylib (4.1 - 902.0.48) <18374D5D-40BA-3256-AF60-E0AF1AF1711D> /Applications/WebODM Manager.app/Contents/Frameworks/libswiftFoundation.dylib
0x10bcbf000 - 0x10bcc2ff3 +libswiftIOKit.dylib (4.1 - 902.0.48) <1795AAF4-889B-3329-9401-3A57C148737E> /Applications/WebODM Manager.app/Contents/Frameworks/libswiftIOKit.dylib
0x10bcc8000 - 0x10bcd0fff +libswiftMetal.dylib (4.1 - 902.0.48) /Applications/WebODM Manager.app/Contents/Frameworks/libswiftMetal.dylib
0x10bcdd000 - 0x10bce3ff7 +libswiftObjectiveC.dylib (4.1 - 902.0.48) <44B0800A-D132-39F7-A811-ABE15940F8D7> /Applications/WebODM Manager.app/Contents/Frameworks/libswiftObjectiveC.dylib
0x10bcef000 - 0x10bcf6ff7 +libswiftQuartzCore.dylib (4.1 - 902.0.48) <5BB0A8D5-6A30-3759-9AA4-8E035E7F2098> /Applications/WebODM Manager.app/Contents/Frameworks/libswiftQuartzCore.dylib
0x10bd02000 - 0x10bd05fff +libswiftXPC.dylib (4.1 - 902.0.48) /Applications/WebODM Manager.app/Contents/Frameworks/libswiftXPC.dylib
0x10bd11000 - 0x10bd16ff7 +libswiftos.dylib (4.1 - 902.0.48) <3323D2C3-53A7-35E0-8F41-DA9BB31F6EE9> /Applications/WebODM Manager.app/Contents/Frameworks/libswiftos.dylib
0x117e0e000 - 0x117e4bdc7 dyld (433.5) <93EA668C-4BB2-3646-96E9-B406B81308D6> /usr/lib/dyld
0x7fffc9dd4000 - 0x7fffca119ff7 com.apple.RawCamera.bundle (7.04 - 914) <86A67D11-9791-3CE6-9FF5-3387C0AB925B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fffcb950000 - 0x7fffcbb11fff com.apple.avfoundation (2.0 - 1187.36) <2F390EAD-07BB-3788-9E73-13104C2E04CD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fffcbb12000 - 0x7fffcbbb4ff7 com.apple.audio.AVFAudio (1.0 - ???) <7997D588-B542-3EBB-B822-D719C1114BB4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fffcbc7f000 - 0x7fffcbc7ffff com.apple.Accelerate (1.11 - Accelerate 1.11) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fffcbc80000 - 0x7fffcbc97ff3 libCGInterfaces.dylib (331.5) <02E9DD16-C5CB-3482-84EF-AA6188A0D28C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fffcbc98000 - 0x7fffcc2d8fe3 com.apple.vImage (8.1 - ???) <4C535C25-EF87-35BE-9BE8-D080A5C24084> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fffcc2d9000 - 0x7fffcc4a0fef libBLAS.dylib (1185.50.4) <7AF8DB9A-E33B-30EB-8767-87AFB951E231> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fffcc4a1000 - 0x7fffcc4b8fff libBNNS.dylib (15) <26F32264-148E-35E5-A280-CA035CB3D6F0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fffcc4b9000 - 0x7fffcc8c4fff libLAPACK.dylib (1185.50.4) <51B2BABA-F736-3663-885A-65A8991D3560> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fffcc8c5000 - 0x7fffcc8dbfff libLinearAlgebra.dylib (1185.50.4) <0EC25E70-05DC-3615-85B6-81721566CF1D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fffcc8dc000 - 0x7fffcc8e2fff libQuadrature.dylib (3) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fffcc8e3000 - 0x7fffcc8f6ff7 libSparseBLAS.dylib (1185.50.4) <0BDCF6A7-0228-3719-81C7-B6EBC7911320> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fffcc8f7000 - 0x7fffcca44ff7 libvDSP.dylib (600.60.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fffcca45000 - 0x7fffccafcfe3 libvMisc.dylib (600.60.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fffccafd000 - 0x7fffccafdfff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fffccdbc000 - 0x7fffcdb95ff3 com.apple.AppKit (6.9 - 1504.83.101) <9BE62551-6557-3E49-9894-6917D403E8F8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fffcdba7000 - 0x7fffcdba7fff com.apple.ApplicationServices (48 - 48) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fffcdba8000 - 0x7fffcdc16ff7 com.apple.ApplicationServices.ATS (377 - 422.3) <73C230CF-3213-3DCA-B528-664FEC76A90C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fffcdcb0000 - 0x7fffcdddffff libFontParser.dylib (194.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fffcdde0000 - 0x7fffcde2afff libFontRegistry.dylib (196.4) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fffcde87000 - 0x7fffcdebafff libTrueTypeScaler.dylib (194.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fffcdf27000 - 0x7fffcdfd1ff7 com.apple.ColorSync (4.12.0 - 502.2) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fffcdfd2000 - 0x7fffce023fff com.apple.HIServices (1.22 - 593) <045870A9-1D92-3FEF-8722-671E99A35E71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fffce024000 - 0x7fffce033ff3 com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fffce034000 - 0x7fffce081fff com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fffce082000 - 0x7fffce0bdfff com.apple.QD (3.12 - 313) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fffce0be000 - 0x7fffce0c9fff com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fffce0ca000 - 0x7fffce2d6ff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <1F4026C6-23C1-39E8-823D-72298FECF75C> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fffce2d7000 - 0x7fffce2d7fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <2CEE36AF-79E6-3B3E-B369-285E6C1886F7> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fffce440000 - 0x7fffce81cfff com.apple.CFNetwork (811.8 - 811.8) <3FB812CB-F4BF-3C47-B772-042FC4D59A33> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fffce836000 - 0x7fffce836fff com.apple.Carbon (154 - 157) <69F403C7-F0CB-34E6-89B0-235CF4978C17> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fffce837000 - 0x7fffce83afff com.apple.CommonPanels (1.2.6 - 98) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fffce83b000 - 0x7fffceb44fff com.apple.HIToolbox (2.1.1 - 857.8) <5367366E-747E-32CF-8E76-93CD8E7424C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fffceb45000 - 0x7fffceb48ff7 com.apple.help (1.3.5 - 49) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fffceb49000 - 0x7fffceb4efff com.apple.ImageCapture (9.0 - 9.0) <341252B4-E082-361A-B756-6A330259C741> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fffceb4f000 - 0x7fffcebe6ff3 com.apple.ink.framework (10.9 - 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fffcebe7000 - 0x7fffcec01fff com.apple.openscripting (1.7 - 172.1) <78F3256B-AF4C-324A-A591-ECA4443A469F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fffcec02000 - 0x7fffcec03ff3 com.apple.print.framework.Print (12 - 267) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fffcec04000 - 0x7fffcec06ff7 com.apple.securityhi (9.0 - 55006) <3AA3E67A-83BF-3EA8-A751-570D9856735B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fffcec07000 - 0x7fffcec0dff7 com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fffcecee000 - 0x7fffceceefff com.apple.Cocoa (6.11 - 22) <85EDFBE1-75F0-369E-8CA8-C6A639B98FA6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fffcee38000 - 0x7fffceec5fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fffceec6000 - 0x7fffceed9fff com.apple.CoreBluetooth (1.0 - 1) /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fffceeda000 - 0x7fffcf1d9ff3 com.apple.CoreData (120 - 754.2) <0C9D9D78-758D-318F-9049-D42CC7944363> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fffcf1da000 - 0x7fffcf287ff7 com.apple.CoreDisplay (1.0 - 1) <53D1EAFE-23A4-398D-BF52-E4299E670DB6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fffcf288000 - 0x7fffcf71bfff com.apple.CoreFoundation (6.9 - 1349.90) <64B31A0D-6A3E-3DEB-A90A-99514C9AEE51> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fffcf71c000 - 0x7fffcfdbfff7 com.apple.CoreGraphics (2.0 - 1070.22) /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fffcfdc0000 - 0x7fffd0003ffb com.apple.CoreImage (12.4.0 - 451.4.9) /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fffd006a000 - 0x7fffd011bfff com.apple.CoreMedia (1.0 - 1907.59.1.6) <570690D8-A956-3629-9E46-4F8BDDB8A82C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fffd011c000 - 0x7fffd0167ff7 com.apple.CoreMediaIO (805.0 - 4932) <15668A10-FD6B-34BB-A14D-F4CE4DAF2887> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fffd0168000 - 0x7fffd0168fff com.apple.CoreServices (775.19 - 775.19) <5046FF69-034E-3570-AC30-D14AA469F669> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fffd0169000 - 0x7fffd01bafff com.apple.AE (712.5 - 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fffd01bb000 - 0x7fffd0496ff7 com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fffd0497000 - 0x7fffd04cafff com.apple.DictionaryServices (1.2 - 274) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fffd04cb000 - 0x7fffd04d3ff3 com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fffd04d4000 - 0x7fffd0640ff7 com.apple.LaunchServices (775.19 - 775.19) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fffd0641000 - 0x7fffd06f1ffb com.apple.Metadata (10.7.0 - 1075.40) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fffd06f2000 - 0x7fffd0751fff com.apple.CoreServices.OSServices (775.19 - 775.19) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fffd0752000 - 0x7fffd07c2fff com.apple.SearchKit (1.4.0 - 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fffd07c3000 - 0x7fffd0808ff7 com.apple.coreservices.SharedFileList (38 - 38) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fffd0891000 - 0x7fffd09deffb com.apple.CoreText (352.0 - 544.16) <543AFBA5-4E6B-3F81-BC45-81ED9707BD9C> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fffd09df000 - 0x7fffd0a14ff3 com.apple.CoreVideo (1.8 - 235.3) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fffd0a15000 - 0x7fffd0a86ffb com.apple.framework.CoreWLAN (11.0 - 1200.31) <4D57D932-6D66-3800-8D33-13951D2E0D84> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fffd0b84000 - 0x7fffd0b89fff com.apple.DiskArbitration (2.7 - 2.7) <70F56042-EF04-3BAF-9E04-90F423FB2BCC> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fffd0d1b000 - 0x7fffd10c1fff com.apple.Foundation (6.9 - 1349.91) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fffd10ed000 - 0x7fffd111eff7 com.apple.GSS (4.0 - 2.0) <30A77A95-CBD4-3BD7-9BFF-8426071F5D9D> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fffd11de000 - 0x7fffd1281fff com.apple.Bluetooth (5.0.5 - 5.0.5f1) <7BC341AE-0207-3670-AD01-27687D9D6F5E> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fffd1282000 - 0x7fffd1318ff7 com.apple.framework.IOKit (2.0.2 - 1324.60.4) <454036AD-86AA-3ABB-8C53-B5F654A6824D> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fffd1319000 - 0x7fffd131fffb com.apple.IOSurface (159.12 - 159.12) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fffd1320000 - 0x7fffd1371ff7 com.apple.ImageCaptureCore (7.0 - 7.0) /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fffd1372000 - 0x7fffd14d5ff7 com.apple.ImageIO.framework (3.3.0 - 1599.13) <02485BF4-7DF2-3F3D-8094-EB827BD1B4C5> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fffd14d6000 - 0x7fffd14dafff libGIF.dylib (1599.13) <1B88A605-C756-36D7-9E3F-570B9A404749> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fffd14db000 - 0x7fffd15ccff7 libJP2.dylib (1599.13) <89654B36-38DC-38FF-9BEE-6755CC964C1C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fffd15cd000 - 0x7fffd15f0fff libJPEG.dylib (1599.13) <3A0067C0-60E1-3CF6-AA26-64CA6428E4BB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fffd15f1000 - 0x7fffd1617fff libPng.dylib (1599.13) <9E8B004C-A532-3DBE-865C-E1A606E16AAF> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fffd1618000 - 0x7fffd161aff3 libRadiance.dylib (1599.13) <3B14C3B1-D4B2-3680-997E-D01DB99634DB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fffd161b000 - 0x7fffd1669ff7 libTIFF.dylib (1599.13) <4B84F502-7F4C-3A21-812D-5B0442FDFAF9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fffd17c7000 - 0x7fffd23d1fff com.apple.JavaScriptCore (12603 - 12603.3.8) <9557271A-1838-38DD-93E3-D8A9ECDE3B6B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fffd23d2000 - 0x7fffd23ebff7 com.apple.Kerberos (3.0 - 1) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fffd2675000 - 0x7fffd267bfff com.apple.MediaAccessibility (1.0 - 97.1.1) <0BD82735-6644-37CE-B13D-8E7CC59A1752> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fffd2691000 - 0x7fffd2bcaff7 com.apple.MediaToolbox (1.0 - 1907.59.1.6) /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fffd2bcb000 - 0x7fffd2c26fff com.apple.Metal (87.18 - 87.18) /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fffd350f000 - 0x7fffd3517fff com.apple.NetFS (6.0 - 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fffd38bf000 - 0x7fffd390dff3 com.apple.opencl (2.8.6 - 2.8.6) /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
3/3
0x7fffd390e000 - 0x7fffd3927ffb com.apple.CFOpenDirectory (10.12 - 194) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fffd3928000 - 0x7fffd3933ff7 com.apple.OpenDirectory (10.12 - 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fffd3934000 - 0x7fffd3936fff libCVMSPluginSupport.dylib (14.0.16) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fffd3937000 - 0x7fffd393aff7 libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fffd393b000 - 0x7fffd393ffff libCoreVMClient.dylib (156.3) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fffd3940000 - 0x7fffd3949ff7 libGFXShared.dylib (14.0.16) <170D07F3-2D30-3D4B-80A0-971E0A765709> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fffd394a000 - 0x7fffd3955fff libGL.dylib (14.0.16) <0801F3B9-A525-32BB-9BC0-478947CE21D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fffd3956000 - 0x7fffd3992ff7 libGLImage.dylib (14.0.16) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fffd3b0a000 - 0x7fffd3b4bff7 libGLU.dylib (14.0.16) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fffd44b3000 - 0x7fffd44c1fff com.apple.opengl (14.0.16 - 14.0.16) /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fffd4730000 - 0x7fffd4877fff com.apple.QTKit (7.7.3 - 2978.8) <80B27C5D-087F-3B83-AF99-AD6BA2E1105D> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fffd4878000 - 0x7fffd4ae2ff7 com.apple.imageKit (3.0 - 1023) <9C547565-CBAA-3ACB-A3F6-1366A0DCDCB4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fffd4ae3000 - 0x7fffd4baafff com.apple.PDFKit (1.0 - 1) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fffd4bab000 - 0x7fffd50d1ff7 com.apple.QuartzComposer (5.1 - 356) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fffd50d2000 - 0x7fffd50f5ffb com.apple.quartzfilters (1.10.0 - 1.10.0) <365342ED-7A1A-3C75-AE60-90764E96034C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fffd50f6000 - 0x7fffd51e3fff com.apple.QuickLookUIFramework (5.0 - 720.7) <3136C23E-399E-3296-928A-B18EC9FC423C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fffd51e4000 - 0x7fffd51e4fff com.apple.quartzframework (1.5 - 21) <09455972-8A33-3D61-B193-BA7E7CF984CA> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fffd51e5000 - 0x7fffd53e5fff com.apple.QuartzCore (1.11 - 453.39.5) <34F65F8C-01D2-3120-BD04-2620BB652D50> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fffd53e6000 - 0x7fffd543bfff com.apple.QuickLookFramework (5.0 - 720.7) <3BD7BA2F-924C-3EFF-B26E-3F930E62E6B4> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fffd543c000 - 0x7fffd5452fff com.apple.SafariServices.framework (12604 - 12604.5.6.1.1) <8B44CF12-8B46-3E05-A6E6-8B726BEDF7D5> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fffd594d000 - 0x7fffd5c4fff7 com.apple.security (7.0 - 57740.60.22) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fffd5c50000 - 0x7fffd5cc5fff com.apple.securityfoundation (6.0 - 55132.50.7) /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fffd5cf0000 - 0x7fffd5cf3ff3 com.apple.xpc.ServiceManagement (1.0 - 1) /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fffd607a000 - 0x7fffd60e9ff7 com.apple.SystemConfiguration (1.14 - 1.14) /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fffd60ea000 - 0x7fffd6498fff com.apple.VideoToolbox (1.0 - 1907.59.1.6) /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fffd8940000 - 0x7fffd895bff3 com.apple.AppContainer (4.0 - 307.50.21) /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fffd895c000 - 0x7fffd8969ff3 com.apple.AppSandbox (4.0 - 307.50.21) /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fffd896a000 - 0x7fffd898cffb com.apple.framework.Apple80211 (12.0 - 1200.47) <869BFE4C-3F15-349E-9715-0A48ED725EAE> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fffd898d000 - 0x7fffd899cfeb com.apple.AppleFSCompression (88.50.3 - 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fffd8a8c000 - 0x7fffd8b1797f com.apple.AppleJPEG (1.0 - 1) /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fffd8b50000 - 0x7fffd8b53ff3 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <42A1731A-A576-307A-B07C-9F8F64696CB7> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fffd8b54000 - 0x7fffd8ba6fff com.apple.AppleVAFramework (5.0.36 - 5.0.36) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fffd8f4a000 - 0x7fffd8fc8ff7 com.apple.backup.framework (1.8.5 - 1.8.5) /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fffd9c53000 - 0x7fffd9c7aff3 com.apple.ChunkingLibrary (173 - 173) /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fffda59f000 - 0x7fffda5a8ffb com.apple.CommonAuth (4.0 - 2.0) <44E4467E-90BB-3CC4-9E57-9B09D7E90081> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fffda72d000 - 0x7fffdab0cff7 com.apple.CoreAUC (226.0.0 - 226.0.0) /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fffdab0d000 - 0x7fffdab3dfff com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <3F6857D1-AE7C-3593-B064-930F5BB7269E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fffdacf1000 - 0x7fffdad01fff com.apple.CoreEmoji (1.0 - 40.3.3) /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fffdadc6000 - 0x7fffdaddcff3 com.apple.CoreMediaAuthoring (2.2 - 956) /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fffdade3000 - 0x7fffdae73ffb com.apple.CorePDF (4.0 - 4) <7F50E4A6-940C-33F5-BE4E-7E01AFE98A8F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fffdb03c000 - 0x7fffdb06cff3 com.apple.CoreServicesInternal (276.2 - 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fffdb2fd000 - 0x7fffdb38cff7 com.apple.CoreSymbolication (62046) <9685A34A-C6FD-3681-8F7E-211D48298DD2> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fffdb38d000 - 0x7fffdb4ccfe7 com.apple.coreui (2.1 - 431.3) <8D0FA478-9B6C-3D6D-8ADF-8677BA0BF134> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fffdb4cd000 - 0x7fffdb59dff3 com.apple.CoreUtils (5.1 - 510.31) <4AC4A8E9-C1E8-3FBA-AF0E-96F9404D826D> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fffdb5ed000 - 0x7fffdb652ff3 com.apple.framework.CoreWiFi (12.0 - 1200.31) /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fffdb653000 - 0x7fffdb661ff7 com.apple.CrashReporterSupport (10.12 - 827) <802A9B81-E349-348B-90AB-10E40B654250> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fffdb6d3000 - 0x7fffdb6ddffb com.apple.framework.DFRFoundation (1.0 - 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fffdb6de000 - 0x7fffdb6e2ff3 com.apple.DSExternalDisplay (3.1 - 380) <4B5E3FF0-E8C3-38CC-BF72-418C928956AB> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fffdb718000 - 0x7fffdb78dffb com.apple.datadetectorscore (7.0 - 539.1) <84F04DEF-DF0A-3F93-AEE9-B6FAC781164B> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fffdb7c9000 - 0x7fffdb808fff com.apple.DebugSymbols (137 - 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fffdb809000 - 0x7fffdb91afff com.apple.desktopservices (1.11.5 - 1.11.5) <46A9D4F3-1EF8-373C-98A4-AD48D285E484> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fffdba5d000 - 0x7fffdba68fff com.apple.DisplayServicesFW (3.1 - 380) <0BDF6C17-5E5F-33F8-8E99-C7350C6F9667> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fffdbc02000 - 0x7fffdc033ff7 com.apple.vision.FaceCore (3.3.2 - 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fffdd38a000 - 0x7fffdd38afff libmetal_timestamp.dylib (600.0.49.9) /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fffdd65b000 - 0x7fffdd677fff com.apple.GenerationalStorage (2.0 - 267.1) <3DE1C580-D089-362D-8582-8DE68A3C5F13> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fffddd88000 - 0x7fffdddfeff3 com.apple.Heimdal (4.0 - 2.0) <9541C717-96FF-32D3-8F0B-5048525DAA70> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fffde419000 - 0x7fffde420ffb com.apple.IOAccelerator (311.16.2 - 311.16.2) <96FA28B6-B03D-3A5E-AF07-0AE4486D2968> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fffde422000 - 0x7fffde436ff7 com.apple.IOPresentment (1.0 - 29.10) <30DF04EE-10E2-353F-845F-A97B87DF3207> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fffde437000 - 0x7fffde459fff com.apple.IconServices (74.4 - 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fffde4f5000 - 0x7fffde505ff3 com.apple.IntlPreferences (2.0 - 216) <15B0DF1F-24C3-3A51-9032-1DD150B7D321> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fffde540000 - 0x7fffde6f7fff com.apple.LanguageModeling (1.0 - 123.2.5) /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fffded67000 - 0x7fffded6afff com.apple.Mangrove (1.0 - 1) <98814966-FD65-302B-B47E-00928DC34E5C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fffdf018000 - 0x7fffdf091ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fffdf1f7000 - 0x7fffdf205fff com.apple.MobileKeyBag (2.0 - 1.0) /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fffdf216000 - 0x7fffdf23eff7 com.apple.MultitouchSupport.framework (368.16 - 368.16) /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fffdf2f0000 - 0x7fffdf2fbfff com.apple.NetAuth (6.2 - 6.2) <97F487D6-8089-31A8-B68C-6C1EAC6ED1B5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fffdfbd3000 - 0x7fffdfc14ff3 com.apple.PerformanceAnalysis (1.148.3 - 148.3) /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fffe02fc000 - 0x7fffe0316fff com.apple.ProtocolBuffer (1 - 249.1) /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fffe0317000 - 0x7fffe0326ff7 com.apple.QuickLookThumbnailing (1.0 - 1) <173EE873-1700-3FCA-9782-C060FBB5BCAD> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fffe032f000 - 0x7fffe0352ff3 com.apple.RemoteViewServices (2.0 - 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fffe101c000 - 0x7fffe101ffff com.apple.SecCodeWrapper (4.0 - 307.50.21) /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fffe10ae000 - 0x7fffe113bfff com.apple.Sharing (696.2.67 - 696.2.67) /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fffe115c000 - 0x7fffe13d1ffb com.apple.SkyLight (1.600.0 - 170.3) <02648329-DEBD-387D-A065-D62A8C0294F5> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fffe15b0000 - 0x7fffe15bcff7 com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fffe1ca8000 - 0x7fffe1d1cfdf com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fffe215b000 - 0x7fffe2161ff7 com.apple.TCC (1.0 - 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fffe21ed000 - 0x7fffe22b3ff7 com.apple.TextureIO (2.8 - 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fffe2329000 - 0x7fffe24b9ff3 com.apple.UIFoundation (1.0 - 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fffe2f88000 - 0x7fffe3048fff com.apple.ViewBridge (283 - 283) <25A635B3-C87C-3D3A-ADF3-539713FA1048> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fffe3493000 - 0x7fffe3499fff com.apple.XPCService (2.0 - 1) <4B28B225-2105-33F4-9ED0-F04288FF4FB1> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fffe356a000 - 0x7fffe356cffb com.apple.loginsupport (1.0 - 1) /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fffe35c1000 - 0x7fffe35dcff7 libCRFSuite.dylib (34) /usr/lib/libCRFSuite.dylib
0x7fffe35dd000 - 0x7fffe35e8fff libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
0x7fffe367a000 - 0x7fffe367bff3 libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fffe367c000 - 0x7fffe388ffff libFosl_dynamic.dylib (16.39) /usr/lib/libFosl_dynamic.dylib
0x7fffe38ab000 - 0x7fffe38b2fff libMatch.1.dylib (27) <70D4BD2A-9383-37F2-B0D6-9B592D236601> /usr/lib/libMatch.1.dylib
0x7fffe38b3000 - 0x7fffe38b3fff libOpenScriptingUtil.dylib (172.1) <0F1BA407-97D1-36F6-882D-A355EAAD5E00> /usr/lib/libOpenScriptingUtil.dylib
0x7fffe38b4000 - 0x7fffe38b8ffb libScreenReader.dylib (477.40.6) /usr/lib/libScreenReader.dylib
0x7fffe38b9000 - 0x7fffe38baffb libSystem.B.dylib (1238.60.2) /usr/lib/libSystem.B.dylib
0x7fffe3926000 - 0x7fffe3951ff3 libarchive.2.dylib (41.70.2) <907D1FB1-9A65-33F5-AFC8-0B6E5AE9D83A> /usr/lib/libarchive.2.dylib
0x7fffe3952000 - 0x7fffe3a47fef libate.dylib (1.12.13) /usr/lib/libate.dylib
0x7fffe3a4b000 - 0x7fffe3a4bff3 libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
0x7fffe3a4c000 - 0x7fffe3a5cff3 libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
0x7fffe3a5d000 - 0x7fffe3a6bff7 libbz2.1.0.dylib (38) /usr/lib/libbz2.1.0.dylib
0x7fffe3a6c000 - 0x7fffe3ac2ff7 libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
0x7fffe3ac3000 - 0x7fffe3aecff7 libc++abi.dylib (307.4) /usr/lib/libc++abi.dylib
0x7fffe3aed000 - 0x7fffe3afdffb libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
0x7fffe3afe000 - 0x7fffe3b14ff7 libcompression.dylib (39) /usr/lib/libcompression.dylib
0x7fffe3b15000 - 0x7fffe3b15ff7 libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
0x7fffe3b16000 - 0x7fffe3b17ff3 libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
0x7fffe3e53000 - 0x7fffe3ea6ff7 libcups.2.dylib (450) <9950BFCB-7882-33C9-9ECF-CE66773C5657> /usr/lib/libcups.2.dylib
0x7fffe3efa000 - 0x7fffe3f01ff3 libdscsym.dylib (148.3) <2A78774F-6679-3B72-9903-B295B9825872> /usr/lib/libdscsym.dylib
0x7fffe3f23000 - 0x7fffe3f23fff libenergytrace.dylib (15) /usr/lib/libenergytrace.dylib
0x7fffe3f33000 - 0x7fffe3f38ff7 libheimdal-asn1.dylib (498.50.9) <92C953A2-5E1D-39E9-875E-92F29A12D6FB> /usr/lib/libheimdal-asn1.dylib
0x7fffe3f39000 - 0x7fffe402bff7 libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
0x7fffe402c000 - 0x7fffe4251ffb libicucore.A.dylib (57167.0.1) /usr/lib/libicucore.A.dylib
0x7fffe4257000 - 0x7fffe4258fff liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
0x7fffe4259000 - 0x7fffe4272ffb liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
0x7fffe4273000 - 0x7fffe4289ff7 libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
0x7fffe428a000 - 0x7fffe4532ff7 libmecabra.dylib (744.8) /usr/lib/libmecabra.dylib
0x7fffe4565000 - 0x7fffe45dfff3 libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
0x7fffe45e0000 - 0x7fffe49b5bc7 libobjc.A.dylib (709.1) <4DF3C25C-52C2-3F01-A3EF-0D9D53A73C1C> /usr/lib/libobjc.A.dylib
0x7fffe49b8000 - 0x7fffe49bcfff libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
0x7fffe49bd000 - 0x7fffe49eefff libpcap.A.dylib (67.60.2) /usr/lib/libpcap.A.dylib
0x7fffe4a0b000 - 0x7fffe4a27ffb libresolv.9.dylib (64) /usr/lib/libresolv.9.dylib
0x7fffe4a28000 - 0x7fffe4a61fff libsandbox.1.dylib (592.70.2) /usr/lib/libsandbox.1.dylib
0x7fffe4a75000 - 0x7fffe4a76ff3 libspindump.dylib (231.3) <9E50A114-FC58-3E22-9027-5002B60005BE> /usr/lib/libspindump.dylib
0x7fffe4a77000 - 0x7fffe4bbdfff libsqlite3.dylib (254.8) <058036FD-6EF3-3F9C-BF9B-2CB7A57205D7> /usr/lib/libsqlite3.dylib
0x7fffe4cb2000 - 0x7fffe4cbffff libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib
0x7fffe4cc0000 - 0x7fffe4dafff3 libxml2.2.dylib (30.18) <75135C3D-47B1-3217-AC2B-B566E2E1A4A3> /usr/lib/libxml2.2.dylib
0x7fffe4db0000 - 0x7fffe4dd9fff libxslt.1.dylib (15.9.1) /usr/lib/libxslt.1.dylib
0x7fffe4dda000 - 0x7fffe4debff3 libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
0x7fffe4dfa000 - 0x7fffe4dfeff7 libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
0x7fffe4dff000 - 0x7fffe4e09fff libcommonCrypto.dylib (60092.50.5) <8A64D1B0-C70E-385C-92F0-E669079FDA90> /usr/lib/system/libcommonCrypto.dylib
0x7fffe4e0a000 - 0x7fffe4e11fff libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
0x7fffe4e12000 - 0x7fffe4e1afff libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
0x7fffe4e1b000 - 0x7fffe4e9efdf libcorecrypto.dylib (442.50.19) <65D7165E-2E71-335D-A2D6-33F78E2DF0C1> /usr/lib/system/libcorecrypto.dylib
0x7fffe4e9f000 - 0x7fffe4ed0fff libdispatch.dylib (703.50.37) <6582BAD6-ED27-3B30-B620-90B1C5A4AE3C> /usr/lib/system/libdispatch.dylib
0x7fffe4ed1000 - 0x7fffe4ed6ffb libdyld.dylib (433.5) <128FF2BB-D0C8-36D9-A456-C1077E7BB182> /usr/lib/system/libdyld.dylib
0x7fffe4ed7000 - 0x7fffe4ed7ffb libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
0x7fffe4ed8000 - 0x7fffe4ee4fff libkxld.dylib (3789.73.8) /usr/lib/system/libkxld.dylib
0x7fffe4ee5000 - 0x7fffe4ee5fff liblaunch.dylib (972.70.1) /usr/lib/system/liblaunch.dylib
0x7fffe4ee6000 - 0x7fffe4eebff3 libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
0x7fffe4eec000 - 0x7fffe4eeeff3 libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib
0x7fffe4eef000 - 0x7fffe4ef0ffb libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
0x7fffe4ef1000 - 0x7fffe4f09ff7 libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
0x7fffe4f0a000 - 0x7fffe4f0aff7 libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
0x7fffe4f0b000 - 0x7fffe4f98fef libsystem_c.dylib (1158.50.2) /usr/lib/system/libsystem_c.dylib
0x7fffe4f99000 - 0x7fffe4f9cffb libsystem_configuration.dylib (888.60.2) /usr/lib/system/libsystem_configuration.dylib
0x7fffe4f9d000 - 0x7fffe4fa0fff libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib
0x7fffe4fa1000 - 0x7fffe4fb9fff libsystem_coretls.dylib (121.50.4) /usr/lib/system/libsystem_coretls.dylib
0x7fffe4fba000 - 0x7fffe4fc0fff libsystem_dnssd.dylib (765.50.9) /usr/lib/system/libsystem_dnssd.dylib
0x7fffe4fc1000 - 0x7fffe4feaff7 libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
0x7fffe4feb000 - 0x7fffe500dff7 libsystem_kernel.dylib (3789.73.8) <7F77BDE8-93F4-3A2D-B864-95AE10DCEA60> /usr/lib/system/libsystem_kernel.dylib
0x7fffe500e000 - 0x7fffe5055fe7 libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib
0x7fffe5056000 - 0x7fffe5074ff7 libsystem_malloc.dylib (116.50.8) /usr/lib/system/libsystem_malloc.dylib
0x7fffe5075000 - 0x7fffe50ceffb libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
0x7fffe50cf000 - 0x7fffe50d8ff3 libsystem_networkextension.dylib (563.60.2) /usr/lib/system/libsystem_networkextension.dylib
0x7fffe50d9000 - 0x7fffe50e2ff3 libsystem_notify.dylib (165.20.1) /usr/lib/system/libsystem_notify.dylib
0x7fffe50e3000 - 0x7fffe50ebfe7 libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7E> /usr/lib/system/libsystem_platform.dylib
0x7fffe50ec000 - 0x7fffe50f6ff7 libsystem_pthread.dylib (218.60.3) /usr/lib/system/libsystem_pthread.dylib
0x7fffe50f7000 - 0x7fffe50faff7 libsystem_sandbox.dylib (592.70.2) <19320A42-2E3B-361B-BBDA-2F5F2E87B100> /usr/lib/system/libsystem_sandbox.dylib
0x7fffe50fb000 - 0x7fffe50fcff3 libsystem_secinit.dylib (24.50.4) /usr/lib/system/libsystem_secinit.dylib
0x7fffe50fd000 - 0x7fffe5104ffb libsystem_symptoms.dylib (532.50.47) <3390E07C-C1CE-348F-ADBD-2C5440B45EAA> /usr/lib/system/libsystem_symptoms.dylib
0x7fffe5105000 - 0x7fffe5118ff7 libsystem_trace.dylib (518.70.1) /usr/lib/system/libsystem_trace.dylib
0x7fffe5119000 - 0x7fffe511effb libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib
0x7fffe511f000 - 0x7fffe5148ff7 libxpc.dylib (972.70.1) /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 106
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=295.3M resident=0K(0%) swapped_out_or_unallocated=295.3M(100%)
Writable regions: Total=89.7M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=89.7M(100%)
                            VIRTUAL   REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 128K 2
Activity Tracing 256K 2
CG image 28K 6
CoreAnimation 1904K 13
CoreUI image data 764K 11
CoreUI image file 184K 5
Foundation 4K 2
Image IO 44K 2
Kernel Alloc Once 8K 2
MALLOC 59.9M 33
MALLOC guard page 48K 10
STACK GUARD 56.0M 7
Stack 10.5M 7
VM_ALLOCATE 24K 5
__DATA 25.5M 257
__IMAGE 528K 2
__LINKEDIT 118.7M 22
__TEXT 176.7M 259
__UNICODE 556K 2
mapped file 49.9M 15
shared memory 16.3M 13
TOTAL 518.0M 656
Model: MacBookPro9,2, BootROM MBP91.00D7.B00, 2 processors, Intel Core i7, 2,9 GHz, 8 GB, SMC 2.2f44
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x802C, 0x384B54463531323634485A2D314736453220
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x802C, 0x384B54463531323634485A2D314736453220
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF5), Broadcom BCM43xx 1.0 (7.21.171.133.1a2)
Bluetooth: Version 5.0.5f1, 3 services, 17 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD HTS545050A7E362, 500,11 GB
Serial ATA Device: HL-DT-ST DVDRW GS41N
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: Hub
USB Device: Apple Internal Keyboard / Trackpad
USB Device: IR Receiver
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB 3.0 Bus
Thunderbolt Bus: MacBook Pro, Apple Inc., 25.1
Thanks for the information!
It’s a really odd problem, it looks like the program is being “sandboxed”, although I have no idea why that is happening. My suspect is that a third party application is doing it, but I can’t confirm. I don’t have a solution for this.
Contact me in private https://masseranolabs.com/contact/, I can issue you a refund for your order (it looks like you were just trying to get a DEM, so you probably don’t need the installer anyhow).
To generate a DEM, simply pass --dsm to the command you are using to launch ODM… for example:
docker run -ti [.....] opendronemap/odm --dsm
Results are stored in the odm_dem directory (which you might need to mount, depending on the command you are using).
Thanks for your help.
I use this command>
docker run -ti --rm -v /Users/juandiegovele/Desktop/odm:/datasets/code opendronemap/opendronemap --project-path /datasets
could you explain me how to use the other command to get DEM files
Then just run:
docker run -ti --rm -v /Users/juandiegovele/Desktop/odm:/datasets/code opendronemap/odm --project-path /datasets --dsm
Note the --dsm parameter. Also use opendronemap/odm, not opendronemap/opendronemap.
Thank you very much Piero, It works perfect.
