Window 10 version of WebODM v 1.9.16 build 73
Help is much appreciated.
Troubleshooting steps already done:
- I already uninstalled and reinstalled. It ran once, but when I restarted, it reverts to this error.
- Rebooted my pc, and still this issue.
Log entries:
“Booting WebODM 1.9.16 build 73…”
“Trying to connect to NodeODM localhost:29301…”
“Attempt 0 failed, retrying…”
“nodeodm: info: Authentication using SimpleToken\r\n”
“nodeodm: info: Listening on 0.0.0.0:6367 UDP for progress updates\r\n”
“nodeodm: info: Initialized 0 tasks\r\n”
“nodeodm: info: Checking for orphaned directories to be removed…\r\n”
“nodeodm: info: Server has started on port 29301\r\n”
“Connected to NodeODM 2.2.0”
“redis-server: . \n .-__ ''-._ \n _.-
. ‘’-._ Redis 3.2.100 (00000000/0) 64 bit\n .- .-```. ```\\/ _.,_ ''-._ \n ( ' , .-` | `, ) Running in standalone mode\n |`-._`-...-` __...-.
-.|’_.-'| Port: 29379\n |
-. ._ / _.-' | PID: 10716\n
-._ -._
-./ .-’ .-’ \n |-._
-. -.__.-' _.-'_.-'| \n |
-.-._ _.-'_.-' | http://redis.io \n
-._ -._
-..-’.-’ .-’ \n |-._
-.-._ _.-'_.-' | \n
-._ -._
-..-’_.-’ _.-’ \n -._
-..-’ _.-’ \n -._ _.-' \n
-..-’ \n\n[10716] 10 Nov 13:09:59.895 # Server started, Redis version 3.2.100\n”
“redis-server: [10716] 10 Nov 13:09:59.898 * DB loaded from disk: 0.003 seconds\n[10716] 10 Nov 13:09:59.898 * The server is now ready to accept connections on port 29379\n”
“G:\WebODM\resources\app\apps\pgsql/bin/pg_ctl: waiting for server to shut down…”
“G:\WebODM\resources\app\apps\pgsql/bin/pg_ctl: .”
“G:\WebODM\resources\app\apps\pgsql/bin/pg_ctl: done\r\nserver stopped\r\n”
“G:\WebODM\resources\app\apps\pgsql/bin/pg_ctl: exited with code 0”
“Trying to connect to postgres localhost:29543…”
“G:\WebODM\resources\app\apps\pgsql/bin/pg_ctl: server starting\r\n”
“G:\WebODM\resources\app\apps\pgsql/bin/psql: exited with code 0”
“python: Operations to perform:\r\n Apply all migrations: admin, app, auth, contenttypes, guardian, nodeodm, sessions\r\nRunning migrations:\r\n No migrations to apply.\r\n”
“python: exited with code 0”
“python: Traceback (most recent call last):\r\n File “G:\WebODM\resources\app\apps\WebODM\manage.py”, line 22, in \r\n”
“python: execute_from_command_line(sys.argv)\r\n File “G:\WebODM\resources\app\apps\grass78\Python39\lib\site-packages\django\core\management\init.py”, line 381, in execute_from_command_line\r\n”
“python: utility.execute()\r\n File “G:\WebODM\resources\app\apps\grass78\Python39\lib\site-packages\django\core\management\init.py”, line 375, in execute\r\n”
“python: self.fetch_command(subcommand).run_from_argv(self.argv)\r\n File “G:\WebODM\resources\app\apps\grass78\Python39\lib\site-packages\django\core\management\base.py”, line 323, in run_from_argv\r\n”
“python: self.execute(*args, **cmd_options)\r\n File “G:\WebODM\resources\app\apps\grass78\Python39\lib\site-packages\django\core\management\base.py”, line 364, in execute\r\n”
“python: output = self.handle(*args, **options)\r\n File “G:\WebODM\resources\app\apps\WebODM\app\management\commands\addnode.py”, line 17, in handle\r\n”
“python: ProcessingNode.objects.update_or_create(hostname=options.get(‘host’), \r\n File “G:\WebODM\resources\app\apps\grass78\Python39\lib\site-packages\django\db\models\manager.py”, line 82, in manager_method\r\n”
“python: return getattr(self.get_queryset(), name)(*args, **kwargs)\r\n File “G:\WebODM\resources\app\apps\grass78\Python39\lib\site-packages\django\db\models\query.py”, line 554, in update_or_create\r\n”
“python: obj = self.select_for_update().get(**kwargs)\r\n File “G:\WebODM\resources\app\apps\grass78\Python39\lib\site-packages\django\db\models\query.py”, line 410, in get\r\n”
“python: raise self.model.MultipleObjectsReturned(\r\nnodeodm.models.MultipleObjectsReturned: get() returned more than one ProcessingNode – it returned 2!\r\n”
“python: exited with code 1”
