Hi all, I try to install webodb and get an error,
thin it asking me a hyper-v, and Im frety sure it is…
Any clue?
[02]: Hyper-V Virtual Ethernet Adapter
Requisitos Hyper-V: Se detect¢ un hipervisor. No se mostrar n las caracter¡sticas necesarias para Hyper-V.
Detected Windows 10 with Hyper-V support
Initializing console…
error during connect: Get http://%2F%2F.%2Fpipe%2Fdocker_engine/v1.39/containers/json: open //./pipe/docker_engine: El sistema no puede encontrar el archivo especificado. In the default daemon configuration on Windows, the docker client must be run elevated to connect. This error may also indicate that the docker daemon is not running.
