I thought I read when editing the processing parameters that hybrid bundle adjustment was a bit quicker, so thought I’d test it on this 8305 image set. However, watching the log I’m seeing 30sec-3 mins between each image addition, vs 3-6 seconds in the previous task where I did not have it set.
Previous 3530 image set took 28 hours to complete, but I can see this taking many weeks with it taking 10 - 30 times as long to add each image.
So the question is, do I write off the 42 hours already spent on this task and try again without hybrid bundle adjustment, or persevere in the hope that it will suddenly get faster towards the end?
For the same images, note the vastly different times to add the next image
No hybrid bundle adjustment:
2021-11-07 16:23:56,822 INFO: DJI_0560_3.JPG resection inliers: 3428 / 3510
2021-11-07 16:23:56,888 INFO: Adding DJI_0560_3.JPG to the reconstruction
2021-11-07 16:24:01,150 INFO: -------------------------------------------------------
2021-11-07 16:24:01,277 INFO: DJI_0577_3.JPG resection inliers: 3662 / 3746
2021-11-07 16:24:01,351 INFO: Adding DJI_0577_3.JPG to the reconstruction
Hybrid bundle adjustment:
2021-11-09 16:01:39,886 INFO: DJI_0560_3.JPG resection inliers: 3394 / 3521
2021-11-09 16:01:39,954 INFO: Adding DJI_0560_3.JPG to the reconstruction
2021-11-09 16:01:40,644 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 3.010221e+00, Final cost: 2.095883e+00, Termination: CONVERGENCE
2021-11-09 16:02:06,814 INFO: Removed outliers: 37
2021-11-09 16:02:14,650 INFO: -------------------------------------------------------
2021-11-09 16:02:14,844 INFO: DJI_0577_3.JPG resection inliers: 3751 / 3827
2021-11-09 16:02:14,929 INFO: Adding DJI_0577_3.JPG to the reconstruction
2021-11-09 16:02:15,571 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 2.597850e+00, Final cost: 1.778209e+00, Termination: CONVERGENCE
2021-11-09 16:02:42,766 INFO: Removed outliers: 30
2021-11-09 16:02:50,502 INFO: -------------------------------------------------------
