How to update portable usb version of ODM installed onto Ubuntu 16.04
We have bought the portable usb version odm for $57. How do we update it as it is running 0.9.1. any help would be great.
Hey @wcarroll14 :hand: we typically update the LiveODM ISO every few months, after the software has been tested for a while.
The 1.1.0 version should end up being available in the ISO sometimes in the next 2 weeks. I can update you when that happens.
Thanks for the reply, a message would be great when the update comes out as well with instructions on how to update. We would also like to know if there are log files stored any where from processing jobs.
LiveODM has not been updated. You can download the LiveODM ISO using the same link you’ve received when you purchased it and flash it onto a USB drive. Simply flash and reinstall.
Logs are usually available from each task within WebODM (just expand the task and press “Task Output --> ON”.
