Hi all,
I am trying to upload only 8 images in the WebODM dashboard but it says ‘cannot process dataset’.
I use flylitchi for DJI drones (I have the mini 2). I had only a few images turn out with the the gimbal looking -90 degrees at the ground. I did run the images through exiftool, although I’m not really sure if that is typically necessary, I found it on YouTube and thought maybe I should try it. I’m self taught here, and it’s not proving to be easy to troubleshoot.
I use chrome on android with windows 10. I bought, downloaded and installed the WebODM software for $77 CDN.
I am attaching the 8 images I took; I know that is not very many images, I set my drone launch app to take a pic every 3 seconds, however the gimbal setting got messed up so I was left with only 8 images.
I am thinking that this was not successful because there are so few images or because it is difficult for the images to be meshed together due to the snow.
Please help!
Options: dsm: true, dtm: true, feature-quality: ultra, gps-accuracy: 10, use-exif: true
[INFO] Initializing ODM 2.7.1 - Thu Mar 03 21:25:03 2022
[INFO] ==============
[INFO] auto_boundary: False
[INFO] boundary: {}
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] cog: True
[INFO] copy_to: None
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: True
[INFO] dtm: True
[INFO] fast_orthophoto: False
[INFO] feature_quality: ultra
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10.0
[INFO] ignore_gsd: False
[INFO] matcher_neighbors: 8
[INFO] matcher_type: flann
[INFO] max_concurrency: 8
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] min_num_features: 8000
[INFO] name: 15d28a7f-9221-497c-a57e-3a98a2db51e8
[INFO] orthophoto_kmz: False
[INFO] orthophoto_png: False
[INFO] pc_classify: True
[INFO] pc_csv: False
[INFO] pc_ept: True
[INFO] pc_filter: 2.5
[INFO] pc_geometric: False
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: [‘odm_postprocess’]
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] skip_orthophoto: False
[INFO] skip_report: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: True
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: C:\WebODM\resources\app\apps\NodeODM\data\15d28a7f-9221-497c-a57e-3a98a2db51e8\images
[INFO] Loading images database: C:\WebODM\resources\app\apps\NodeODM\data\15d28a7f-9221-497c-a57e-3a98a2db51e8\images.json
[INFO] Found 8 usable images
[INFO] Coordinates file already exist: C:\WebODM\resources\app\apps\NodeODM\data\15d28a7f-9221-497c-a57e-3a98a2db51e8\odm_georeferencing\coords.txt
[INFO] Model geo file already exist: C:\WebODM\resources\app\apps\NodeODM\data\15d28a7f-9221-497c-a57e-3a98a2db51e8\odm_georeferencing\odm_georeferencing_model_geo.txt
[INFO] Parsing SRS header: WGS84 UTM 20N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[WARNING] C:\WebODM\resources\app\apps\NodeODM\data\15d28a7f-9221-497c-a57e-3a98a2db51e8\opensfm\image_list.txt already exists, not rerunning OpenSfM setup
[WARNING] C:\WebODM\resources\app\apps\NodeODM\data\15d28a7f-9221-497c-a57e-3a98a2db51e8\opensfm\exif already exists, not rerunning photo to metadata
[WARNING] Detect features already done: C:\WebODM\resources\app\apps\NodeODM\data\15d28a7f-9221-497c-a57e-3a98a2db51e8\opensfm\features exists
[WARNING] Match features already done: C:\WebODM\resources\app\apps\NodeODM\data\15d28a7f-9221-497c-a57e-3a98a2db51e8\opensfm\matches exists
[WARNING] Found a valid OpenSfM tracks file in: C:\WebODM\resources\app\apps\NodeODM\data\15d28a7f-9221-497c-a57e-3a98a2db51e8\opensfm\tracks.csv
[WARNING] Found a valid OpenSfM reconstruction file in: C:\WebODM\resources\app\apps\NodeODM\data\15d28a7f-9221-497c-a57e-3a98a2db51e8\opensfm\reconstruction.json
I’m 100% open to watching how to do all of this on YouTube, I have been trying to find the help for a couple of days and I thank you in advance for any help you can give me.
