How to speed up?
How to speed up image processing and compositing, in addition to using distributed?
Hey @tinyRatP :hand: could you expand on your question?
WebODM already attempts to use all available resources. Perhaps you could consider using a computer with more CPU cores to speed up processing. Also make sure you’ve allocated enough CPU cores to docker, if you are using it.
Does anyone have recommendation on a CPU and core size? Presently I’m using a Broadwell-E i7 6850K Desktop CPU 6 core 12 tread 3.6ghz chip. I allocated half to Docker and a 450 image project has been running all night and show about half completed!
Any help would be appreciated!
if your computer has 6 cores I would let docker use one extra core, or the other option is upgrade to a higher CPU. odm runs on your cpu and ram.
Yes. You could probably get away with taking 5 of the 6 cores, but it’s probably wiser to use 4 of the 6.
Thanks for the comments which I will try.
