I want to send proj string to specify coordinate system of outputs as parameter to WebODM. Is it even possible ? Let say i modified “def extract_utm_coords(photos, images_path, output_coords_file)” function inside ODM, will ODM process it properly ?
I guess it is not posssible, i saw a comment in ODM code;
# Convert GCP file to a UTM projection since the rest of the pipeline
# does not handle other SRS well
You can adjust the output CRS for many products using the 2D Map View as of release v1.9.11:
